problem starting with microsoft visual studio
Posted 04 August 2012 - 01:02 PM
Posted 04 August 2012 - 02:39 PM
First of all, be sure the .NET MF is installed. To do it, open Visual Studio alone, click in New Project and try to find in Visual C# the option Micro Framework. If you can do it, the .NET MF is correctly installed.
Other problem you could have is the *sln file, If you are open I project made in Visual Studio Ultimate and try to opening on Visual Studio Express *.sln file could be cause a trouble, so delete de *.sln file (most times this file is in the same folder that project file *.sln).
PS: Sorry my bad English!
Victor.
Good day all
i'm a newbie in netduino and a microsoft visual studio(c #). i recently installed microsoft visual studio on my laptop,and i have install the micro framework sdk and the netduino sdk because i'm using netduino for the project i'm busy with. but i'm having a problem to open a new project with the microsoft visual studio ( c#),every time i try saving the project after a select the netduino application under microsoft frame work it says " the Project file'c://document and settings/nbayondo/local settings/temp/eclaspp2.gif/temp/Netduino Application2.csproj' cannot be opened...the project type is not supported by this application." could please help me to sort out this problem. thanks in advance
Posted 07 August 2012 - 05:54 AM
Posted 07 September 2012 - 04:15 PM
Posted 10 November 2012 - 07:45 PM
good day, sorry i come back late with the response, i am still experiencing the same problem of opening a new project visual studio professional 2010(c#). could you please help me in this situations.thank you in advance
I have today the same problem with visual basic 2010 express.
First of all I started with c# in visual studio 2010 express. This is working fine.
To test a visual basic solution I installed the basic version, updated to SP1 and getting the same error: the project type is not supported by this installation.
Then I tried to create a project with netduino plus template, other error and same problem: the project file cannot be created.
Creating a windows forms project, no problem at all.
I use the .NET SDK 4.2 (QFE2) micro framework on a windows xp home computer.
Posted 10 November 2012 - 08:10 PM
Posted 11 November 2012 - 09:12 AM
Hi plakias,
Can you try uninstalling and then reinstalling the NETMF 4.2 and Netduino SDKs?
The error seems to indicate that Visual Basic doesn't understand the NETMF project type.
Hello Chris,
I uninstalled and reinstalled the NETMF 4.2.
Started C# visual studio 2010. Project loads ok.
Started vb visual studio 2010. The project loads ok.
Reinstalling .NET framework SDK 4.2 did the trick.
Thank you!
ps: It was not my intention to hijack this topic.
Posted 11 November 2012 - 05:25 PM
Thank you!
No problem! We're here to help. Glad you're up and running and hopefully this thread helps others who might find themselves in the same situation.
