Serial communication with FTDI Breakout Reloaded V1.1
27 replies to this topic
#1 inxtremo
inxtremo
  • 32 posts
Posted 10 February 2012 - 05:31 PM
i bought the following breakout board and want to communicate serial with my windows application and the netudino.
I wired the RX-Port from the breakout board with Digital Pin 0 and the TX-Port with the Digital Pin 1. Gnd to Gnd. I hoped the wiring is the same like here.
When i send a send a message with SerialPort.Write("blaa"), the breakout board receives a signal, the led on the board blinks but my netduino recieves no data.
Code on Netduino:
using System.IO.Ports;
namespace NetduinoStepperControl
        static SerialPort serial;
            // initialize the serial port for COM1 (using D0 & D1)
            serial = new SerialPort(SerialPorts.COM1, 115200, Parity.None, 8, StopBits.One);
            // open the serial-port, so we can send & receive data
            serial.Open();
            // add an event-handler for handling incoming data
            serial.DataReceived += new SerialDataReceivedEventHandler(serial_DataReceived);
            serial.ErrorReceived += new SerialErrorReceivedEventHandler(serial_ErrorReceived);
            // wait forever...
        static void serial_ErrorReceived(object sender, SerialErrorReceivedEventArgs e)
            Debug.Print(e.ToString());
        static void serial_DataReceived(object sender, SerialDataReceivedEventArgs e)
            Debug.Print("Data received");
            // create a single byte array
            byte[] bytes = new byte[1];
            // as long as there is data waiting to be read
            while (serial.BytesToRead > 0)
                // read a single byte
                serial.Read(bytes, 0, bytes.Length);
                // send the same byte back
                serial.Write(bytes, 0, bytes.Length);
Code in Application:
using System.Text;
using System.Diagnostics;
namespace Plugin{
    [System.Serializable()]
    public class NetduinoControllerPlugin : System.MarshalByRefObject, IControllerPluginService
        static SerialPort _serial;
    private String _name = "Netduino Controller Service";
        public String Name
            get { return this._name; }
            set { this._name = value; }
        private String _description = "foo";
        public String Description
            get { return this._description; }
            set { this._description = value; }
        public void Initialize()
            Console.WriteLine("Initialize called");
            try
                _serial = new SerialPort("COM3", 115200, Parity.None, 8, StopBits.One);
                _serial.DataReceived += new SerialDataReceivedEventHandler(_serial_DataReceived);
                _serial.ErrorReceived += new SerialErrorReceivedEventHandler(_serial_ErrorReceived);
                _serial.Open();
            catch (Exception e)
                System.Diagnostics.Trace.WriteLine(e);
            //Thread.Sleep(Timeout.Infinite);
        void _serial_ErrorReceived(object sender, SerialErrorReceivedEventArgs e)
            Console.WriteLine(e.ToString());
        static void _serial_DataReceived(object sender, SerialDataReceivedEventArgs e)
            // wait a little for the buffer to fill
            System.Threading.Thread.Sleep(100);
            // create an array for the incoming bytes
            byte[] bytes = new byte[_serial.BytesToRead];
            // read the bytes
            _serial.Read(bytes, 0, bytes.Length);
            // convert the bytes into a string
            string line = System.Text.Encoding.UTF8.GetString(bytes);
            // write the received bytes, as a string, to the console
            System.Console.WriteLine("echo: " + line);
            System.Console.WriteLine();
        /// <summary>
        /// double deg, int onTime, int offTime, bool onFirst, uint repeat
        /// </summary>
        /// <param name="deg" example="180 -> 180 degree to left">0, 10, 100, 360, -360, -100, -10, 0</param>
        /// <param name="onTime" example="100 -> 100ms">0 - x</param>
        /// <param name="ofTime" example="100 -> 100ms">0 - x</param>
        /// <param name="onFirst" example="0 -> false" example="1 -> true"></param>
        /// <param name="repeat" example="1 -> repeats once">0, 1, 2, ...</param>
        public void MoveUp(int steps)
            Console.WriteLine("MoveUp {0} Steps", steps);
            String msg = steps + ",1,1,1,1";
            _serial.Write(Encoding.UTF8.GetBytes(msg), 0, msg.Length);
Anyone a suggestion?
Thanks and best regards,
Daniel
#2 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 10 February 2012 - 07:26 PM
I believe the pins are backwards. I have the same setup and my RX is on D1 and my TX is on D0.
#3 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 10 February 2012 - 07:31 PM
Also, try a lower baud rate first. The higher the rate, the higher the likeliness of errors.
Furthermore, when serial is not working, always try swapping the cables, the question of wether TX or RX is the signal going in or out from where is always a matter of who's team you're playing for.
In analogy, according to the nazi's, Adolf was the good guy Posted Image
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 10 February 2012 - 08:14 PM
Sorry for the unintentionally possibly rude joke that will probably get me banned from here. If it does, let me just say, I'm originating from Austria, so it was all on my own expense really.
#5 inxtremo
inxtremo
  • 32 posts
Posted 13 February 2012 - 07:23 AM
Hi an thanks for the answers. I tried to swapping the cables, same problem. The lower baud rate also didn´t work. I am no electronic guy, but the setup with this breakout board should work? Or have i bought the wrong hardware? Thanks and best greetings, Daniel
#6 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 13 February 2012 - 11:56 AM
Daniel
What is the switch on the side set for? It switches between 3.3v and 5v. If you are using it on Com1 it should be set for 3.3v.
#7 inxtremo
inxtremo
  • 32 posts
Posted 13 February 2012 - 12:41 PM
Is switches between 3.3v and 5v, right. I have it set on 3.3v. I also tried to use Digital Port 2 and 3, but same problem there. After work i will try a code from the net that should work with an USB BUB, seen here
Maybe my code is wrong.
Greetings
#8 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 13 February 2012 - 12:59 PM
Greetings
I am using a different FTDI board from SparkFun but probably uses the same chips. I have it wired to pins 0 & 1 and my wires are crossed (TX = > RX and RX => TX).
The code I am using works fine here are some clips.
My Static Members
    	// The serial port
    	static SerialPort _port;
    	// current data position and packet length
    	static int count, readLength;
    	// Are we reading data from the port
    	static bool reading = false;
    	// Send data back to forms app or not
    	static bool bounce = false;
    	// Storage for our incoming data
    	static byte[] inTray;
Create and Open Serial Port
// Define the port, "COM1" Netduino digital pins D0(RX), D1(TX) at 115200 Baud
_port = new SerialPort("COM1", 115200, Parity.None, 8, StopBits.One);
_port.DataReceived += new SerialDataReceivedEventHandler(ReceivedData);
_port.Open();
My Receive Event Handler
    	static void ReceivedData(object sender, SerialDataReceivedEventArgs e)
        	//Debug.Print("Data Received");
        	// Get the number of incoming bytes
        	int bytes = _port.BytesToRead;
        	// Create a new temporary store
        	byte[] data = new byte[bytes];
        	// Read in the bytes
        	_port.Read(data, 0, bytes);
        	// Check to see if this is a new read
        	// if so reset the system and get the
        	// length of the incoming data
        	if (!reading)
            	reading = true;
            	count = 0;
            	readLength = data[0];
            	inTray = new byte[readLength + 1];
        	// Populate the inTray with the incoming data
        	for (int i = 0; i < bytes; i++)
            	inTray[count] = data[i];
            	count++;
        	// Check to see if we have a full packet
        	ParseRecievedData();
Then I parse out the data
    	private static void ParseRecievedData()
        	// Check to see if we have a full packet. If so reconstruct data as text
        	if (count > readLength)
            	//Debug.Print("Parse Received Data");
            	// Remove the first byte as this is the length indicator
            	// not part of the message
            	byte[] outTray = new byte[inTray.Length - 1];
            	Array.Copy(inTray, 1, outTray, 0, outTray.Length);
            	// Convert the bytes back into a string
            	string text = new string(Encoding.UTF8.GetChars(outTray));
            	// Reset the reading state
            	reading = false;
            	// Use our new data to do something
            	DoSomethingWithData(text);
Then finally my DoSomethingWithData method has a switch to run different commands based on the text received. I don't recall exactly where I saw this example but it does work and works well at 115200 baud. I've had it even higher baud for simple one word commands.
#9 inxtremo
inxtremo
  • 32 posts
Posted 13 February 2012 - 01:16 PM
Hey thanks, i will try the code this evening after work. Hope it works. Greetings, Daniel
#10 inxtremo
inxtremo
  • 32 posts
Posted 13 February 2012 - 04:16 PM
:unsure: no way. I tried an working code but the netduino don´t respond. Also if i pinging the netduino (serial) over the MFDeploy Tool, "Error: no response from device" Should i upgrade the firmware? Actual Firmware version on my netduino is 4.1.0.6 Maybe my netduino or the ftdi is broken but both are nearly new. Greetings, Daniel
#11 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 13 February 2012 - 06:52 PM
:unsure: no way.
Greetings,
Daniel
When I started I was using 4.1.1 b1 because of another issue and I know it worked with that. I'm not sure if it worked with 4.1.0.6.
Here is a crazy question, do you have the FTDI's ground connected to Netduino ground?
#12 inxtremo
inxtremo
  • 32 posts
Posted 13 February 2012 - 07:19 PM
Ok, i´ll try an beta firmware, may it work.
Yes, i grounded the ftfi. I connected the stuff like here.
#13 inxtremo
inxtremo
  • 32 posts
Posted 14 February 2012 - 07:04 AM
Good Morning,
here is the status quo.
I upgraded my firmware this evening with the new beta firmware Version: 4.2.0 RELEASE CANDIDATE (version 4.2.0.0 RC4)from here. There was a exciting 1 hour procedure but finally the firmware works :rolleyes:
The problem with the serial connection is the same. I can send via COM3 to the FTDI, the "TX"-LED on the FTDI blinks if i send a message but there is no reaction from the netduino.
I ordered a "USB BUB" this evening. This FTDI must work.
The next step, i´d like to connect the FTDI and the netduino on a other PC and try it there.
#14 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 14 February 2012 - 07:52 AM
I assume you now get a response when pinging the device from MFDeploy? As you know, this is a reguirement for anything else to work.
I use a FTDI cable like this one:
http://www.sparkfun.com/products/9717
This cable talks to the Netduino UART on a 3.3V TTL level and it always works very well for me. It is starting to sound as if your FTDI breakout board is broken.
#15 inxtremo
inxtremo
  • 32 posts
Posted 14 February 2012 - 08:01 AM
Do you now get a response when pinging the device from MFDeploy? This is a reguirement for anything else to work.
Good Morning,
no i didn´t test the ping yesterday after the firmware upgrade. I will test it today after work. I saw this cable earlier but it seems that there are only a few shops in Germany that sell such stuff. I ordered the USB BUB in Netherlands.
Is there a possibility to test my netduino if it is broken? As earlier mentioned, i am not that electronic guy and fairly new onto this. As i unboxed the netduino i connected two stepper shields and two stepper motors. Maybe i broke something because of wrong wiring? The two steppers works fine.
#16 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 14 February 2012 - 08:33 AM
Well, if your N+ responds to MFDeploy pings and you can program it via the onboard USB, it should be fine. The Netduino is quite durable so I doubt there is anything wrong with yours. Try something really simple, like the Blinky:
http://www.netduino....ects/blinky.zip
EDIT: If you mean to test the UART in particular, you can always run a loopback test. To do this, simply bridge the tx and rx pins of the intended UART on your N+, then write an application that creates a serial port, sends a few bytes and verifies that the exact same bytes are also received ok.
#17 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 14 February 2012 - 01:09 PM
Another silly question, but when you plug the FTDI board into your PC, does it show up in device manager and what does it show up as? I am just remembering that I had to install drivers on the PC because I was getting the same results as you in the beginning. I am using this breakout board and they had the drivers on the page for download. FDTI Basic Breakout
#18 inxtremo
inxtremo
  • 32 posts
Posted 14 February 2012 - 01:36 PM
Thanks for the tip, i´ll try it later. Blinky and other applications working fine.
The FTDI show up as an USB/Serial-Device as far as i know. Have to look at home. On the original product page are no drivers for download but on the product page for the earlier release of this board. Thanks for the answer, i´ll give it a try. Incidentally, in Germany exisiter a proverb. "There are no silly questions, only stupid answers." So thank you very much for your help.
#19 inxtremo
inxtremo
  • 32 posts
Posted 15 February 2012 - 08:08 AM
Good morning,
things i tried:
  • Installing the Driver for the FTDI Board -> Don´t work
  • Installing the setup on an other PC -> Don´t work
  • Bridge the Ports on the N+ and send commands -> Works
So the N+ is ok. I think the FTDI is broken, may i can send it back. Hope the USB BUB from Netherlands arrives soon, so i can test it. Hope this time it will work.
I think i will test the FTDI-Board like the N+ with bridging the ports.
Greetings and thanks for the good help,
Daniel
#20 inxtremo
inxtremo
  • 32 posts
Posted 15 February 2012 - 08:25 AM
Very interesting. Bridging the ports on the FTDI works too. :blink:
Maybe it is really the wrong FTDI Board for the N+.
