What is the size of the coaxial power connector? I've looked through all the specs and found electrical specs but no physical specs for the connector. I need to get a power cube that matches.
Bernie
Coaxial Power Connector Size
Started by Bernie, Jan 07 2012 03:47 AM
Posted 07 January 2012 - 03:47 AM
Posted 07 January 2012 - 08:14 AM
I use a 5.5mm diameter power plug with 2.1mm diameter centre hole size.
In the UK Maplin part No: HH60Q "DC Power plug 2.1mm/5mm".
Centre pin - positive.
Paul
Posted 08 January 2012 - 06:22 AM
And I believe this is type M.
Posted 08 January 2012 - 06:26 AM
It's a bit odd because the schematic says;
Barrel Power Jack 2.1mm ID, 5.2mm OD
But wikipedia lists all the common sizes here;
http://en.wikipedia....power_connector
and I don't see on that size. I'll probably opt to use a type K, unless anyone from Secret Labs jumps in here.
Bernie
