2.4" TFT Color LCD,touch screen sheild V1.2 for Arduino Mega
Posted 12 March 2011 - 05:45 PM
Been playing around with this LCD shield for a few weeks now and I have just about got it working with my netdunio plus. You can see from the link that it needs quite a few IO pins:
LCD Display
So I've used an MCP23017 for the data/address lines and a MCP2308 for the control lines, reduces the IO load to just using the i2c pins on the netdunio plus. Code wise I've just converted the c++ code produced by the guys at Nuelectronics and used the MCP230xx I2C classes posted by GDSever. On the whole the display works as expected but every now and then I think the initialization code doesn't quite work, still working on fixing this it's probably a timing related problem or my dodgy code .
I'll post a few screen shots soon.
Posted 13 March 2011 - 08:52 AM
Hi All,
LCD Display
Solved the display problem had two of the control lines running off the same pin a quick re-wire and it's all working well. The display is a nice bit of kit, lots of fun to be had.
Posted 13 March 2011 - 09:53 AM
Hi,[...] So I've used an MCP23017 for the data/address lines and a MCP2308 for the control lines, reduces the IO load to just using the i2c pins on the netdunio plus. Code wise I've just converted the c++ code produced by the guys at Nuelectronics and used the MCP230xx I2C classes posted by GDSever. [...]
I want to use a TFT touch screen with my netduino too.
Do you plan to publish your C# code? Especially the ported C++ code, this would be great.
Posted 13 March 2011 - 10:30 AM
Yep plan to publish the code just making a few changes, it's very much experimental.
Posted 13 March 2011 - 12:18 PM
Posted 13 March 2011 - 08:59 PM
Posted 15 March 2011 - 09:42 PM
Posted 29 March 2011 - 12:12 AM
Posted 30 March 2011 - 08:12 AM
I am doubting between two cheap graphical LCD's from nuelectronics:
The Nokia 3310 LCD shield (netduino code for it can be found in another thread on this forum: http://forums.netdui...-nuelectronics/)
Or the 2.4" TFT Color LCD for Arduino Mega, with your initial code.
However, from your first post, I understand that you use additional IC's (MCP230XX) when you use that 2.4" screen. Does it mean that your code is only usable when these same IC's are used, or is it just possible to plug the TFT color LCD shield (originally for arduino mega) directly on the netduino (I have a netduino plus) and to use it with your initial code?
You are correct the code I posted will only work if the additional IC's are used. I used the IO explanders because the Arduino mega shield uses the 16bit interface. As far as I cold tell it's not pin compatible with the netduino. If you want a really fast LCD refresh when it would be better to write the addressing code in native code. I'm looking at using separate MCU to drive the LCD with the netduino plus passing display request to it.
Posted 25 April 2011 - 10:29 PM
