How do the input pins work ?
#1 bgreer5050
bgreer5050
  • 28 posts
Posted 06 February 2015 - 04:43 PM
Can I use input pins in both fashions:
  • Send 3.3 volts to the pin and the controller will detect the pin as interrupted.
  • Ground the pin and the controller will detect the pin as interrupted.
If this is the case, does the controller automatically detect this ?
What is best practice ?
#2 bgreer5050
bgreer5050
  • 28 posts
Posted 07 February 2015 - 10:25 PM
Anyone ?
#3 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 12 February 2015 - 01:49 PM
I am using a Netduino plus v1 with v4.2 firmware.
In C# I use:
InterruptPort port = new InterruptPort(pin, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeLow);
The mode at the end can be set to:
Port.InterruptMode.InterruptEdgeHigh,
Port.InterruptMode.InterruptEdgeLow,
Port.InterruptMode.InterruptEdgeBoth,
Port.InterruptMode.InterruptEdgeLevelHigh,
Port.InterruptMode.InterruptEdgeLevelLow
I think you are describing "Both"
Be aware that after the v4.1 to v4.2 firmware update, there are now two ways to configure inputs - Secret labs and Microsoft. So you may have issues using other people's code snippets unless you get the correct using statements and references. It had me confused for a while.
Hope this helps - Paul
