Netduino CNC
CNC stepper GCode
10 replies to this topic
#1 David S
David S
  • 11 posts
Posted 05 March 2014 - 01:15 PM
Hi everyone,
some time ago I was working on a GCode parser for the netduino. I wanted to share it with you guys, maybe you find it useful in your own home-CNC projects.
It has been sitting on my disk for a while now and I finally found the time to upload it to Github.
It includes a parser that runs on the netduino and a 3D toolpath viewer I used for debugging the parser on the PC side. Here is a screenshot of the viewer:
And here is the code:
https://github.com/d.../Netduino-gcode
Hope that you find it useful! It was great fun to build it.
Cheers!
David
#2 twinnaz
twinnaz
  • 38 posts
  • LocationBrampton, Ontario
Posted 05 March 2014 - 04:42 PM
Nice im going to have to test this out and scrap my code I was writing, haha. Thanks
Netduino Plus 2
#3 twinnaz
twinnaz
  • 38 posts
Posted 05 March 2014 - 05:35 PM
Just tested On my Netduino Plus 2 running .Netmf 4.3 after adding the references and deploying im getting an exception when trying to connect.
Netduino Plus 2
#4 David S
David S
  • 11 posts
Posted 05 March 2014 - 07:59 PM
Maybe you have found it by now. You have to create a config file "gcodeviewer.ini" in the exe directory. This is a .INI file. Add a line with
cnc.address=the IP of your netduino
Sorry, I forgot to document that on the readme.
Cheers!
David
#5 twinnaz
twinnaz
  • 38 posts
Posted 05 March 2014 - 10:59 PM
Alright found that one last question which project do we deploy to the Netduino. I see two solutions NetduinoDevice2  and gcodephaser-Netduino
but when deploying either one of these it deploys quite fast and doesn't go through the regular steps (**As in lights on the Netduino lights up, debugger assembles everything, and then says ready)
Netduino Plus 2
#6 David S
David S
  • 11 posts
Posted 06 March 2014 - 08:53 AM
Select the build configuration "Netduino Debug" and set NetduinoDevice2 as your startup project. Hit F5 and it should deploy and run.
The led on the netduino will blink and finally off once it is listening for connections.
#7 twinnaz
twinnaz
  • 38 posts
Posted 22 March 2014 - 03:23 AM
The program seems to timeout every time after connecting cant seem to find the problem
Netduino Plus 2
#8 David S
David S
  • 11 posts
Posted 22 March 2014 - 09:36 AM
Hi twinnaz,
if you try to connect to the netduino on port 82 with a telnet client (putty, for instance), can you connect? The firmware should print a string like "Dave's CNC interface 0.70 with G-Code" when you connect.
Cheers!
#9 twinnaz
twinnaz
  • 38 posts
Posted 22 March 2014 - 03:47 PM
There was an unreachable code socket.Close() in lineserver.cs
I just changed it and everything's working now
            commSocket.Close();
                        socket.Close();
                        Debug.Print("Netduino server stopped");
Netduino Plus 2
#10 Chris Walker
Posted 25 March 2014 - 07:52 AM
Hi David,
That's pretty awesome. Do you have any videos showing this off in action, etc.? We'd love to share them.
#11 David S
David S
  • 11 posts
Posted 28 March 2014 - 04:40 PM
I made some videos long time ago when I was developing it, but have to dig in backups to find them. I'll upload what I find and post back.
Cheers!
Also tagged with one or more of these keywords: CNC, stepper, GCode
