Best Answer mdredmond, 26 February 2014 - 05:28 PM
So the questions:
- Is anybody tried to build current netduino 2 firmware v4.2.2 source with gcc?
- What necessary to use versions of [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Porting Kit and gcc[/color]?
Denislam:
I believe you used the wrong version of the wiki article you referenced. See this one: http://wiki.netduino...to-GCC-4-6.ashx
Follow it precisely. Install the PK, overwrite with the 4.2.2 firmware sources from SecretLabs, then overwrite with the changes contained in the archive attached to that wiki. Then follow the build instructions to the letter.
I was having the same issue you were. The problem is that the two versions of the wiki article are nearly identical and the link at the top makes it a little confusing as to which firmware version the article applies to.
Go to the full post
