How to reboot netduino + from code on a socket exception?
7 replies to this topic
#1 samjones
samjones
  • 105 posts
Posted 29 January 2012 - 10:04 PM
So once in awhile, netduino can't get on the network,
Soooo, how can I, in code, re-init the enet on such an exception?
Ideally, I can do this in line in the code, so I can keep the debugger attached.
But if a reboot is needed, so be it... tell me how to do that from code....
thx!!
Example of exception below:
'System.Net.Sockets.Socket.Send'
    #### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
    #### Message:
    #### Microsoft.SPOT.Net.SocketNative::send [IP: 0000] ####
    #### System.Net.Sockets.Socket::Send [IP: 0018] ####
    #### System.Net.Sockets.NetworkStream::Write [IP: 0051] ####
    #### System.Net.InputNetworkStreamWrapper::Write [IP: 000a] ####
    #### System.Net.HttpWebRequest::SubmitRequest [IP: 0077] ####
    #### System.Net.HttpWebRequest::GetResponse [IP: 000c] ####
    #### NetduinoPlusApplication1.Program::ProcessRequest [IP: 0016] ####
    #### NetduinoPlusApplication1.Program::GetBusStatus [IP: 0005] ####
    #### NetduinoPlusApplication1.Program::Main [IP: 004c] ####
    #### SocketException ErrorCode = 10054
#2 Valkyrie-MT
Valkyrie-MT
  • 315 posts
  • LocationIndiana, USA
Posted 31 January 2012 - 03:23 AM
You could put a try/catch around your code and in the catch call PowerState.RebootDevice -Valkyrie-MT
#3 ColinR
ColinR
  • 142 posts
Posted 31 January 2012 - 05:08 AM
The trouble you will face is that sometimes the exception is genuine, and sometimes it's due to the networking stack needing a reboot. The method I implemented in the end was an exception count, where after x exceptions, reboot.
#4 samjones
samjones
  • 105 posts
Posted 31 January 2012 - 06:17 AM
Colin, Is there a class out there to easily log exceptions to the sd card? I want to get a picture of what is going on when I am at work.... Thoughts? Thx!
#5 Arbiter
Arbiter
  • 132 posts
  • LocationBrisbane, Australia
Posted 07 February 2012 - 12:33 AM
I wonder would it suffice to release and renew?
NetworkInterface.GetAllNetworkInterfaces()[0].ReleaseDhcpLease();
      NetworkInterface.GetAllNetworkInterfaces()[0].RenewDhcpLease();
#6 ColinR
ColinR
  • 142 posts
Posted 07 February 2012 - 05:26 AM
Just wrap your code in try catch blocks and call WriteLog(exception.ToString());
private static void WriteLog(string log)
    try
        var fs = new FileStream(@"\SD\log.txt", FileMode.Append, FileAccess.Write, FileShare.Read, 512);
        var sw = new StreamWriter(fs);
        sw.WriteLine(DateTime.Now.ToString(DateFormat) + ": " + log.Trim());
        sw.Flush();
        sw.Close();
    catch { }
Unfortunately not according to my tests.
#7 Arbiter
Arbiter
  • 132 posts
Posted 07 February 2012 - 12:34 PM
I built an app that responds to the NetworkAddressChanged event by creating a TCP socket, connecting it to the echo service on port 7, writing "FUBAR" and reading it back into a buffer that it displays with Debug.Print(). This app totally failed to manifest the problem when I power cycle the wireless 3G router to which my N+ is connected.
On the app I have under development, this causes 10055 on the second pass.
Believing it to be a memory shortage, I constructed this
using System.Net;
using System.Net.Sockets;
using Microsoft.SPOT.Net.NetworkInformation;
using System.Text;
namespace NetworkExercise
    static bool isNetworkAvailable = false;
    static byte[] rampig = new byte[15360];
      NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
      NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
    static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
      isNetworkAvailable = e.IsAvailable;
      Debug.Print(DateTime.UtcNow.ToString("u") + " " + (isNetworkAvailable ? "ONLINE" : "OFFLINE"));
    static void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
      if (isNetworkAvailable)
        var na = NetworkInterface.GetAllNetworkInterfaces()[0];
        Debug.Print(na.IPAddress.ToString());
        Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
        var ep = new IPEndPoint(Dns.GetHostEntry("whitehouse.podzone.net").AddressList[0], 7);
        socket.Connect(ep);
        socket.Send(Encoding.UTF8.GetBytes("FUBAR"));
        byte[] buf = new byte[5];
        Thread.Sleep(100);
        socket.Receive(buf);
        Debug.Print(new string(Encoding.UTF8.GetChars(buf)));
Rather surprisingly. this runs without a hitch. Increase rampig by 1K and it doesn't even get off the starting block.
#8 mohammad
mohammad
  • 79 posts
Posted 22 May 2013 - 03:16 AM
This link might be useful to reboot the Netduino Plus by software http://forums.netdui...lus/#entry49735
Good Luck,
Mohammad
