pushing the button sample
#1 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 15 June 2011 - 06:25 PM
Another simple VB-sample:
Imports Microsoft.SPOT
Imports SecretLabs.NETMF.Hardware.Netduino
Module Module1
    Sub Main()
        Dim Led As OutputPort = New OutputPort(Pins.ONBOARD_LED, False)
        Dim Button As InputPort = New InputPort(Pins.ONBOARD_SW1, False, ResistorModes.PullUp)
        Do While True
            Led.Write(Button.Read())
        Loop
    End Sub
End Module
When the onboard button is pushed, the led will light up
#2 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 25 June 2011 - 07:19 AM
I hope I'm not misunderstanding, but when I tried your code it seems that ONBOARD_SW1 is back-to-front. That is, Button.Read() returns true when the switch is NOT being pressed, and false when it is. So should be "When the onboard button is pushed, the led will light up" really read "When the onboard button is pushed, the led will turn off"? PS: Thanks for the post though. Post like these are really helping me to learn how to program the Netduino.
#3 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 25 June 2011 - 07:45 AM
HI Anthony,
Welcome to the Netduino community and thanks for your feedback :)
When I wrote the code the result was actually how I described it in the first post, but I was a bit surprised as well. I think with a newer version of the beta release they've fixed something. In C# it was indeed inverted. Going to test it again later today and if needed I'll modify my code :)
That's the fun of beta software, things are always open for changes! :D
#4 CW2
Posted 25 June 2011 - 05:50 PM
Technically, it is correct - the Read() method returns state of the pin (logic level) and the switch is wired in [very common] way that it causes logic low on the pin when pressed. As Stefan mentioned, it was changed in 4.2 beta firmware to match the button state (i.e. button state = pin state inverted).
