Need help with TFT display and SPI
8 replies to this topic
#1 netiness
netiness
  • 10 posts
  • LocationNorway
Posted 17 October 2013 - 06:29 PM
Still learning but boy is this fun. A big thanks to the people at Secret Labs !!
I have a TFT display like this one
http://www.elecfreak...#External_Links
I have connected it with SCK on D13,MOSI on D11, CS on D10, reset on A1, D/C on A2.
I have converted the source from the above link to C# and have no problem setting pixels on the display. Really slooow, but it works. Now, I would like to try using SPI to speed things up, but have run into some problems.
This is how I have found the SPI should be initialized :
Device1 = new SPI.Configuration(       Pins.GPIO_PIN_D10, // CS-pin       false,             // CS-pin active state       0,                 // The setup time for the SS port        0,                 // The hold time for the SS port       true,              // The idle state of the clock       false,             // The sampling clock edge       1000,              // The SPI clock rate in KHz        SPI_Devices.SPI1   // The used SPI bus (refers to a MOSI MISO and SCLK pinset)   );                SPIBus = new SPI(Device1);
I use the following for sending data/commands to the display. Note that if I set UseSPI=false everything works as expected
 void LCD_Write_Bus(byte data)        {            if (UseSPI)            {                SPIBus.Write(new byte[] { data });            }            else            {                P_CS.Write(false);                for (byte c = 0; c < 8; c++)                {                    P_MOSI.Write((data & 0x80) != 0);                    data = (byte)(data << 1);                    P_SCK.Write(false);                    P_SCK.Write(true);                }                P_CS.Write(true);            }        }        void LCD_Write_COM(byte VL)        {            P_DC.Write(false);            LCD_Write_Bus(VL);        }        void LCD_Write_DATA(byte VL)        {            P_DC.Write(true);            LCD_Write_Bus(VL);        }
Anyone experience who can point me in the right direction ?
Kjetil
#2 netiness
netiness
  • 10 posts
  • LocationNorway
Posted 17 October 2013 - 07:40 PM
Oh well, I figured it out. The configuration was not correct. The Idle state of clock should be false, and the sampling clock edge should be true.
Still a bit too slow, but faster; I am not able to push the clock rate above 1.3 Mhz
#3 netiness
netiness
  • 10 posts
  • LocationNorway
Posted 24 October 2013 - 05:26 PM
Are there anyone else using this kind of display (ILI9341) via SPI ? What clock rates can you use at maximum ? With my current configuration I cannot go above 1311Khz, making the display really slow. I don't have a real understanding of the various initialization parameters for the display, but has hacked together what information I've found on the net. A sample naive project can be found at http://code.google.c...tduino-spi-tft/. The NP2 should be able to pump out data faster than this, right ? Any suggestions are welcome.
Kjetil
#4 pmc
pmc
Posted 26 October 2013 - 04:01 PM
I'm using the DisplayTech STD028ATFT (ILI9341) on the STM and it's pretty fast. Here are my low-level routines if that can help.
  • Attached File  tft.zip   4.83KB   41 downloads
#5 alesbedac
alesbedac
  • 63 posts
Posted 13 December 2013 - 07:00 AM
Coll, but i havent tested it..its not in C#  its in C...is anybody to rewrite it to c# ?
#6 asciiman
asciiman
  • 56 posts
  • LocationTurkey
Posted 29 April 2014 - 06:36 AM
yes
me to need C# code
#7 alesbedac
alesbedac
  • 63 posts
Posted 29 April 2014 - 06:45 AM
I can place here me working example code if you wish...if you help me how to add file to new topic :-).
#8 asciiman
asciiman
  • 56 posts
  • LocationTurkey
Posted 29 April 2014 - 06:53 AM
hi sir
Start new topic and press choose files button bottom of editor
or
press "more reply options" near the post button
you can see attachment button
#9 alesbedac
alesbedac
  • 63 posts
Posted 03 May 2014 - 08:55 AM
http://forums.netdui...ft-lcd-ili9341/
