First Project - Prototype - Industrial Control
#1 SteveAndrews
SteveAndrews
  • 17 posts
  • LocationOrange County, CA
Posted 25 September 2013 - 04:51 AM
After building Hello World, Hello World 2, and playing as one must with LEDs, buttons, buzzers, PWM, servos, and more, here is my first real-world project (prototype). It utilizes a Netduino Pro 2, dual 9V/12V power supplies, SD card, ethernet, a Sainsmart four relay board, three magnetic switches, a kill button, four relays, two DPDT relays which will power an industrial DC motor, and is mounted on a piece of Plexiglas. The code is mostly standard, but contains a micro web server handling GET, POST, and AJAX calls.
The gist of the project is basically industrial lift control via HTTP.
Posted Image
Still to do:
Find a 12 gang, individual feed, studded junction block (or whatever they're called).
Wire up the inputs and outputs on the junction block.
Find a solid and supported WiFi shield.
Glue down the DPDT relays.
Use a hairdryer on the wires to shape them a bit.
Various coding enhancements including auth and cookies.
Being that it's my first real project, I'd love to get some feedback.
#2 Giuliano
Giuliano
  • 361 posts
  • LocationSimi Valley, CA
Posted 25 September 2013 - 04:46 PM
I now you meant to say Netduino Plus 2 and not Netduino Pro 2.
Awesome project, thanks for sharing.
Out of curiosity, how is the micro web server running, does it freeze from time to time?
#3 w5uxh
w5uxh
  • 5 posts
  • LocationLas Cruces, NM
Posted 26 September 2013 - 01:46 AM
I would be interested in seeing your micro web server code as an example to help me figure out how to build a simple server that works with a web page containing text boxes where I can enter text and submit the contents to a server running on the Netduino Plus 2.
I have zero experience with HTTP/HTML etc. and have used google to find some sample code.  I have tested some very crude things using the web server example in the Getting Started with Netduino book as a starting point.  But some additional code with forms/text boxes etc. could be very helpful.
The specific thing I want to do is have two text boxes where I can enter an IP address in one and a PORT number in the other and then submit those items to the server.  I found a very crude way to send the contents of one box when I type something and hit the ENTER key, but the contents of the box are cleared in the process.  This will only be the first step in a project that will use those entries, but one small step at a time.
#4 SteveAndrews
SteveAndrews
  • 17 posts
Posted 26 September 2013 - 07:00 AM
Giuliano: Indeed I did mean Plus 2. :-) Yes, it does. I've found that it can get overloaded, for example when holding down the F5 key to continuously refresh the page. And every now and again it just gets goofy and I'll reset the board. I've also seen issues with certain browsers and chunking the response. I haven't yet looked into these too much, though I'm pretty sure it's the code and not the device or OS.
w5uxh: The basic gist for standard forms is to read the POST verb in the header and then parse the request's body content. There are a number of micro web server projects out there. A few, in no particular order:
http://netduinowebserver.codeplex.com
http://embeddedwebserver.codeplex.com
https://netmfwebserver.codeplex.com
http://neonmikawebserver.codeplex.com
#5 w5uxh
w5uxh
  • 5 posts
Posted 26 September 2013 - 12:23 PM
Steve, thanks for the links.  I will dig through them and see if I can learn enough of the fundamentals to get started.
