USB 3.3V
Posted 02 January 2011 - 11:16 PM
Posted 02 January 2011 - 11:42 PM
Posted 03 January 2011 - 09:59 AM
Posted 03 January 2011 - 07:46 PM
Posted 03 January 2011 - 09:49 PM
I looked only now, into the netduino mini schematic and I notice that only one UART/RS232 will be available if I use one for programing and debug. For the project I have in mind (a hub to install in a RC airplane) I would need one UART and one RS232. Is it possible to use a USB driver/converter to 3.3V and connect it to DDM and DDP and use it like NetDuino?.
Hi Manuel,
For that, I'd recommend using a Netduino with an RS232 shield for debugging...and then you can flash your final application onto the Netduino Mini.
You can use both ports on the Netduino Mini but that will shut off the debugging capability. If you do use both ports, simply drive the "DTR" pin high on the Netduino Mini during power-up to kick it into bootloader mode when you want to erase the current app.
Posted 03 January 2011 - 09:58 PM
