Sending data to php website
http php website request post
Best Answer Dave1374, 12 August 2013 - 12:17 PM
Hey VanKurt.
This is how I send data to my wcf service.
string query = "http://www.x.com/Service1.svc/Log?Log=" + data;using (HttpWebRequest myReq = (HttpWebRequest)WebRequest.Create(query)){    myReq.Method = "GET";    using (HttpWebResponse WebResp = (HttpWebResponse)myReq.GetResponse())    {          }}
Both objects require
using System.Net;
Maybe I'm doing it wrong tho... didn't know the netmf toolbox had a httpclient class.
You should had try catch to the code snippet btw.
here's an interesting stackoverflow topic about the using statement. not to be confused with the one to access a namespace.
edit: heh just realised you already had usings in your code... so, yeah.
Dave
#1 VanKurt
VanKurt
  • 19 posts
Posted 10 August 2013 - 01:38 PM
Hi there!
I'm currently trying to send data from the netduino plus to my webserver via a special php site. When I call the site manually from my webbrowser everything works fine. But when doing the same via code from the netduino it does not work.
Here's the sending code (inspired by these forums):
private void SendHttpRequest(string serverUrl, string request){  IPHostEntry host = Dns.GetHostEntry(serverUrl);  IPEndPoint endPoint = new IPEndPoint(host.AddressList[0], 80);  using (Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp))  {    socket.Connect(endPoint);    using (NetworkStream ns = new NetworkStream(socket))    {      byte[] bytes = System.Text.Encoding.UTF8.GetBytes("GET " + request + " HTTP/1.1rn");      ns.Write(bytes, 0, bytes.Length);    }  }}
And this is how I call it:
SendHttpRequest("www.mywebsite.com", "/netduino/submitData.php?data=5");
The problem is, that the php script on the website is never called. So I guess there is something wrong with the way I send the HTTP request?
Thanks for your help!
#2 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 11 August 2013 - 12:43 PM
Is this PHP script hosted on a shared webserver (i.e. cheap hosting account)?  If so then it will be setup using HostNames for multiple site support from a single IP.  As you are connecting directly to the server by IP you need to specify the hostname for your site as a HTTP header.
If on the other hand the script is hosted locally, try just specifying the IP address of the server and check that you can access your site just by its IP.  As unless the IP is bound to port 80 as well as a host name your server wont respond.
Finally check that the name is being resolved correctly by the Dns call, sometimes i have found the ND to need the DNS server to be specified manually as it wasnt for some reason being assigned by DHCP.
I would also try and use the HttpClient in the netmf toolbox, https://netmftoolbox...ailable classes as it works very well and lets you post data easily as well...
You could also look at the source for inspiration as well.
Nak.
#3 Dave1374
Dave1374
  • 31 posts
Posted 12 August 2013 - 12:17 PM   Best Answer
Hey VanKurt.
using System.Net;
Dave
#4 VanKurt
VanKurt
  • 19 posts
Posted 13 August 2013 - 06:02 AM
Allright, got it working  :D
I ended up including the System.Http assembly, which makes everything nice and easy. And it adds only 30kB to the final application size.
#5 markleeapps
markleeapps
Posted 04 September 2013 - 10:19 PM
VanKurt,
You were trying to send data to your php website, and you got it working with System.Http. Can you please post the code for the Netduino and also the php code.
Also tagged with one or more of these keywords: http, php, website, request, post
