How to read data html with web server?
web server html
8 replies to this topic
#1 Archimede
Archimede
  • Validating
  • 15 posts
Posted 30 July 2013 - 09:46 AM
hi everyone, :) I have a web server that receives data from the browser. The web server sends html code to the browser (html code is a edit text and a button) ... My goal is to read the text written by the user. when the web server receives the data from the browser receives this request that is:
GET / localhost? User = foo HTTP/1.1 Accept: text / html, application / xhtml + xml, * / * ....... .....
In this example the user has written foo which is located in the user "variable" ... How can I filter only the text written by the user? I have used IndexOf() but it doesn't work fine... :wacko:
#2 Dave1374
Dave1374
  • 31 posts
Posted 30 July 2013 - 11:05 AM
Let's try with substring and indeof
string requestAnswer = what You already do to get the data string...
int startIndex = requestAnswer.IndexOf("User =");
int endIndex = requestAnswer.IndexOf("HTTP/1.1");
string data = requestAnswer.Substring(startIndex , endIndex );
hope that helps, i have to leave, ill edit my post later
http://www.dotnetperls.com/substring
http://www.dotnetperls.com/indexof
#3 Archimede
Archimede
  • Validating
  • 15 posts
Posted 30 July 2013 - 10:17 PM
thank you Dave1374, i have tryed the substring and indexOf() but the variable data contains "user textuser http/1.1"....i have used again indexOf() on data and work fine...but when i try to write the text, the server web works fine but after 5-6 tests doesn't work....Why?
Help me please Dave...
i post the code that i have used:
class Server : IDisposable
private Socket socket = null;
public Server()
//Initialize Socket class
socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
//Request and bind to an IP from DHCP server
socket.Bind(new IPEndPoint(IPAddress.Any, 9050));
//Start listen for web requests
socket.Listen(10);
ListenForRequest();
public void ListenForRequest()
using (Socket clientSocket = socket.Accept())
Thread.Sleep(10);
//Get clients IP
IPEndPoint clientIP = clientSocket.RemoteEndPoint as IPEndPoint;
EndPoint clientEndPoint = clientSocket.RemoteEndPoint;
int bytesReceived = clientSocket.Available;
if (bytesReceived > 0)
//code html
string response3 = "<!DOCTYPE html>";
response3 += "<html>";
response3 +="<head>";
response3 +="<title>Netduino Plus</title>";
response3 +="</head>";
response3 +="<body>";
response3 +="<h1>Netduino Plus 2</h1>";
response3 += "<form name="+"input"+" action="+"localhost"+" method="+"get"+">"
+" Username: <input type="+"text"+" name="+"user"+">"
+"<input type=submit value=send>"+
"</form>";
response3 +="</body>";
response3 +="</html>";
clientSocket.Send(Encoding.UTF8.GetBytes(response3), response3.Length, SocketFlags.None);
//Get request
byte[] buffer = new byte[bytesReceived];
int byteCount = clientSocket.Receive(buffer);
//string request = new string(Encoding.UTF8.GetChars(buffer));
string request = Encoding.ASCII.GetString(buffer,0,byteCount);
int startIndex = request.IndexOf("user=");
int endIndex = request.IndexOf("HTTP/1.1");
string dati = request.Substring(startIndex,endIndex);
if (dati.IndexOf("archimede") != -1 )
Debug.Print("text contains your name");
else
if (dati.IndexOf("read") != -1 )
Debug.Print("user wants to read");
else
Debug.Print("text doesn't contain your name ");
Debug.Print(request);
Debug.Print(dati);
#region IDisposable Members
~Server()
Dispose();
public void Dispose()
if (socket != null)
socket.Close();
#endregion
#4 Dave1374
Dave1374
  • 31 posts
Posted 31 July 2013 - 02:15 AM
Hmmm
add a lower case... if it's still not working, it's because the indexof doesnt match exactly the way the data is.
string request = Encoding.ASCII.GetString(buffer,0,byteCount).ToLower();
int endIndex = request.IndexOf("http/1.1");
also i dont see how the data contains "textuser" ...
btw I would change the name of the form
response3 += "<form name='netDuinoForm'  action='localhost' method='get'>"
+" Username: <input type='text' name='user'>"
+"<input type='submit' value='send'>"+
"</form>";
I dont have visual studio installed here so I can't test anything
also you might want to look into .Contains("wordToSearchInAString") , or you may want to look for regular expressions... but I think regex is a bit overkill.
if it doesn't work, send me the full exact data string,
Dave
#5 Archimede
Archimede
  • Validating
  • 15 posts
Posted 31 July 2013 - 02:13 PM
Hi Dave,
i tried to run the server but now i have the error...(i don't know the because...) is argumentOutOfRangeException... i think that startIndex and endIndex haven't the correct contents... it is how if the browser send different request each time that communicates with the server...Yesterday i had no this error...
thanks for your help... you are very polite  :)
P.S. how can i post the code how have you made with my request in your response?(sorry for my english...)
#6 Archimede
Archimede
  • Validating
  • 15 posts
Posted 31 July 2013 - 02:46 PM
Hi Dave, i tried change the data in starIndex i have wrote "get" and the server now work fine..(mystery)...i have added also .ToLower() have made more tests and i haven't the errors... thank you very much... then in future if i will have errors i write in this post for your help... :)
New request : after this experience, i would like to read the radiobutton, for example the browser contains a default state the radio button and when the user change the state of the radio button the server receives this change... can you write an example code...?
#7 Graham.fry
Graham.fry
  • 15 posts
Posted 06 August 2013 - 11:44 AM
Hi
[font="calibri;"]In my request I have limited my response to 2 characters and my var indicator is light= this works every time[/font]
 //Get request
  int byteCount = clientSocket.Receive(buffer, bytesReceived, SocketFlags.None);
  //int countof = request.IndexOf("light="); //for my code
 int countof = request.IndexOf("user=");
  countof = countof + 6;
  //var s = request.Substring(countof, 2); //for my code
You may need to add the following and it may need some tweeking
 int noChatTotext = X //(this is the number of char to the end of user= it should constant)
 int lengthOfrequest = request.length(); //calculate the length of the hole request sent.
 int noCharToGet =  lengthOfrequest - noChatTotext; //the length of the text you want
 var s = request.Substring(countof, noCharToGet); //S will be the text you want
#8 NoxiaZ
NoxiaZ
  • 12 posts
Posted 06 August 2013 - 12:01 PM
Hmm.. think this way is alittle bit better, and you can use it to all the fields :)
string request = "GET / localhost? User = foo HTTP/1.1";Hashtable hashtable = new Hashtable();int indexQuestionMark = request.IndexOf("?");int httpLength = request.Length-request.LastIndexOf(" ") ;string data = request.Substring(indexQuestionMark +1,request.Length-indexQuestionMark-httpLength -1).Trim();string[] fields = data.Split('&');for(int i=0;i < fields.Length;i++){ string[] field = fields[i].Split('='); hashtable.Add(field[0].Trim(),field[1].Trim());}Console.WriteLine(hashtable["User"]);
Hope this help you a bit :)
#9 Archimede
Archimede
  • Validating
  • 15 posts
Posted 21 August 2013 - 07:22 AM
thank you boys for your answers, i will prove to use these code lines...
thank you very much :)
Also tagged with one or more of these keywords: web server, html
