Analog input resolution &
#1 engvidal
engvidal
  • 10 posts
  • LocationGuarulhos - SP - Brazil
Posted 30 July 2013 - 12:09 AM
Hi
If the ADC resolution is 12 bits (from 0 to 4095) why I only obtain a 10 bit result (0 to 1023) ?
and more: Why the line in red (reference [color=#ff0000;]pot1[/color]) do not compile ?
using System.Net;
using System.Net.Sockets;
using SecretLabs.NETMF;
[color=#ff0000;]AnalogInput pot1 = new  AnalogInput(Pins.GPIO_PIN_A1); // DO NOT COMPILE ! ![/color]
  SecretLabs.NETMF.Hardware.AnalogInput  pot =
  new SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A1);
// using the full path compiles, even with the 'using SecretLabs.NETMF.Hardware'
Thank You.
#2 Fahdil
Fahdil
  • 59 posts
  • LocationJakarta, Indonesia
Posted 28 January 2014 - 12:55 PM
Hi
which literature that explain the analog input has 12bits? as i know Netduino has limit the analoginput to 10bits. see Hardware Specification.
[color=rgb(255,0,0);]AnalogInput[/color] pot1 = new AnalogInput(Pins.GPIO_PIN_A1); // DO NOT COMPILE ! !
it's bcoz you're using both:
the netduino with 4.2 framework has the ambiguity. try to delete "Microsoft.SPOT.Hardware".
#3 ShVerni
ShVerni
  • 138 posts
  • LocationNew York, New York
Posted 28 January 2014 - 04:51 PM
As I understand it, the original Netduinos had 10 bit ADCs, while the Netduino 2 and the Netduino Plus 2 (and maybe the Netduino Go?) have a 12 bit ADC.
If you're worried about cross platform compatibility, you should use the Microsoft AnalogInput class, the Read method for which returns a number between 0 and 1 based on the reading, essentially a percentage of the maximum voltage.
To use the Microsoft class you need to use AnalogChannels not Pins:
AnalogInput pot1 = new  AnalogInput(AnalogChannels.ANALOG_PIN_A1);
Check out this thread for more details:
http://forums.netdui...etduino-plus-2/
Hope that helps!
#4 Chris Walker
Posted 31 January 2014 - 03:48 AM
Fahdil -- as ShVerni said, switch over to the new Microsoft.SPOT.Hardware.AnalogInput class and you should be good to go. [Or you can pull in SecretLabs.NETMF.Hardware.AnalogInput if you want to use older code samples.] ShVerni -- thanks for responding to this. P.S. ADCs on Netduino Go vary by module (based on the best precision available on the particular module). Shield Base does have the same 12-bit ADCs as Netduino 2 and Netudino Plus 2.
#5 ShVerni
ShVerni
  • 138 posts
Posted 31 January 2014 - 05:15 AM
ShVerni -- thanks for responding to thisG. P.S. ADCs on Netduino Go vary by module (based on the best precision available on the particular module). Shield Base does have the same 12-bit ADCs as Netduino 2 and Netudino Plus 2.
Glad to help, and thanks for the clarification!
