Link failure with brand new Netduino Plus 2
link failure error
Best Answer VanKurt, 10 August 2013 - 01:39 PM
Yes, you were right. That solved it  ^_^
5 replies to this topic
#1 VanKurt
VanKurt
  • 19 posts
Posted 26 July 2013 - 05:33 PM
Hello,
I just installed VC#, the Netduino SDK 4.2.2.0 and the .NETM-Framework 4.2 as described on this site.
When I try to run my project on the Netduino Plus I get the following errors:
Create TS.
 Loading start at 806a988, end 8085288
Assembly: mscorlib (4.2.0.0)
Assembly: Microsoft.SPOT.Net (4.2.0.0)
Assembly: System (4.2.0.0)
Assembly: System.IO (4.2.0.0)
Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
Assembly: Microsoft.SPOT.Time (4.2.0.0)
Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)
Assembly: Neptune (1.0.0.0)
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0)
Assembly: SecretLabs.NETMF.Hardware (4.1.0.0)
Resolving.
Link failure: some assembly references cannot be resolved!!
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.1.2821.0)
Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0) needs assembly 'mscorlib' (4.1.2821.0)
Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) needs assembly 'mscorlib' (4.1.2821.0)
Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.1.2821.0)
Error: a3000000
I've checked the target Framework version in the project settings. 4.2 should be right, right?
What elso could it be? What diud I do wrong?
#2 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 26 July 2013 - 06:03 PM
Have you upgraded your Netduino to the 4.2 firmware as well?
And installed the Secret Lab 4.2 SDK and updated your references in the project?
Can see a load of references to 4.1 assemblies.
Nak.
#3 VanKurt
VanKurt
  • 19 posts
Posted 26 July 2013 - 06:20 PM
I thought the netduino plus 2 came with 4.2? If that's not the case: how would I upgrade the firmware? I can't see any download for that :-(
#4 nakchak
nakchak
  • 404 posts
Posted 26 July 2013 - 06:21 PM
Ahh yes the Netduino Plus 2 does i believe come with 4.2 already installed.
Check your netduino SDK is the lastest version, as its looking for 4.1 binaries.
Nak.
#5 Chris Walker
Posted 26 July 2013 - 11:58 PM
As nakchak mentioned, Visual Studio is trying to deploy a .NET MF 4.1 application to a .NET MF 4.2 device. In project properties, select NETMF 4.2 under "target framework". Save, redeploy, and you should be good to go. Chris
#6 VanKurt
VanKurt
  • 19 posts
Posted 10 August 2013 - 01:39 PM   Best Answer
