String.Contains - Error with custom 'Contains'
gfcwfzkm
11 replies to this topic
#1 gfcwfzkm
gfcwfzkm
  • 52 posts
  • LocationBrig-Glis, Switzerland
Posted 24 June 2013 - 01:42 PM
i want to search in a text some stuff.
i have a message like this:
GET /PIN=TOGGLE HTTP/1.1 Host: 172.17.0.129 User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:21.0) Gecko/20100101 Firefox/21.0 Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8 Accept-Language: de-de,de;q=0.8,en-us;q=0.5,en;q=0.3 Accept-Encoding: gzip, deflate Connection: keep-alive Cache-Control: max-age=0
And i want to search for 'Chrome' or 'Safari'. Theres no Safari/chrome in that message, but the Contains-Function give me always a True back. i have my Contains-Function from http://forums.netdui...stringcontains/
    <System.Runtime.CompilerServices.Extension()> _    Public Function Contains(ByVal _src As [String], ByVal _search As Char) As Boolean        For i As Integer = _src.Length - 1 To 0 Step -1            If _src.IndexOf(_search) >= 0 Then                Return True            End If        Next        Return False    End Function
Where is the problem :S
mfg
gfc
I uploaded the Full code, its a webserver for the netduino plus (.MF 4.2)
#2 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 24 June 2013 - 10:46 PM
Hi! I'm not sure but could be the VB implementation of the IndexOf imethod s one-based and that zero means "not found". If so just substitute "greater or equal" for just "greater" or simply replace the zero with a one. Also, your loop repeats the same call to IndexOf for as many times as there are characters in _src - is that intentional and if so, why?
#3 baxter
baxter
  • 415 posts
Posted 25 June 2013 - 03:17 AM
Maybe there is something wrong with the Function for a long string. It returns true on the first test of your message when I run it. Also, the Function is only looking for the first character of the test string, not the whole  word.  Put a Debug.Print(_search) before the test. On all of the cases below it prints "C". Otherwise, the function works OK for me. It finds "C". I would look for another "Contains" function if you want to find a whole word.
Dim Test As String = "Chrome"Dim S As String = "'Some text"Dim S1 As String = "Some text with Chrome"Dim S2 As String = "Some text with chrome"Dim B As BooleanB = S.Contains(Test)Debug.Print("Testing S: " & B.ToString)  '<--FalseB = S1.Contains(Test)Debug.Print("Testing S1: " & B.ToString) '<--TrueB = S2.Contains(Test)Debug.Print("Testing S2: " & B.ToString) '<--False
Also, IndexOf always returns -1 if not found.
#4 gfcwfzkm
gfcwfzkm
  • 52 posts
Posted 25 June 2013 - 08:39 AM
I got the answer from http://mikedodaro.ne...icro-framework/ (Blog)
<System.Runtime.CompilerServices.Extension> _Public Shared Function Contains(s As String, value As String) As Boolean    Return s.IndexOf(value) > 0End Function
Problem solved, thx =)
#5 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 25 June 2013 - 08:53 AM
Good, then it was as I suspected and also the solution was the one I suggested earlier:
...If so just substitute "greater or equal" for just "greater" or...
Also, I see you got rid of the redundant calls to IndexOf (as I also mentioned).
#6 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 25 June 2013 - 09:31 AM
In C# it does but are you sure it does so in VB too?
It doesn't seem to judging from the solution and VB is traditionally 1-based.
#7 gfcwfzkm
gfcwfzkm
  • 52 posts
Posted 25 June 2013 - 02:30 PM
It works good, i tried it in a console application:
The output:
True
s slol
False
Module Module1    Sub Main()        Dim x As String = "s Strb slol"        Console.WriteLine(x.Containsx("Strb").ToString)        x = x.Replace("Strb", "")        Console.WriteLine(x)        Console.WriteLine(x.Containsx("Strb").ToString)        Console.ReadLine()    End Sub    <System.Runtime.CompilerServices.Extension()> _    Public Function Containsx(ByVal s As String, ByVal value As String) As Boolean        Return s.IndexOf(value) > 0    End FunctionEnd Module
#8 baxter
baxter
  • 415 posts
Posted 25 June 2013 - 05:50 PM
Well, I always use the construct:
Dim bool As Boolean = If((Not x.IndexOf("Strb") = -1), True, False)orDim bool As Boolean = If((x.IndexOf("Strb") <> -1), True, False)
http://msdn.microsof...y/k8b1470s.aspx
Return Value
Type: System.Int32
The zero-based index position of value if that string is found, or -1 if it is not. If value is String.Empty, the return value is 0.
Incidentally, this will not work in the Micro Framework,
 x = x.Replace("Strb", "") <-- ERROR: Replace is not a member of String
You have to use StringBuilder,
 Dim Sb As StringBuilder = New StringBuilder(x) x = Sb.Replace("Strb", "").ToString
#9 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 25 June 2013 - 06:37 PM
I see, well then I suppose gfcwfzkm's tests did not run under the micro framework but under the regular. Btw, you do mean "iif" and not just plain old "if", right?
#10 baxter
baxter
  • 415 posts
Posted 25 June 2013 - 10:24 PM
No hanzibal, if you type,  Dim bool As Boolean = if(, IntelliSense will show the syntax. I think IIf is no longer supported; at least, it will not show up with IntelliSense. More ...
http://stackoverflow...28377/iif-vs-if
#11 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 25 June 2013 - 10:38 PM
Ah, I was totally unaware of that, thanks for the info. I really liked the last part about the new operator being "short circuit" so that it only evaluates the true alternative and not both as the old iif did. I guess my VB is gettng a bit rusty from all the C#.
#12 JoopC
JoopC
  • 148 posts
Posted 26 June 2013 - 01:24 PM
Visual Basic is a very strong language, and I prefer i above the java clone C# because you can write it very organized.
You can push up your production.......
Also It is not necessary to create so much overhead.
Just do things like this:
Debug.Print(New StringBuilder("hhxhh").Replace("x", "z").ToString)
Also tagged with one or more of these keywords: gfcwfzkm
