Today in the morning with fresh mind I wanted to continue with the project I left yesterday. But when I tried to burn my app its just stuck at "Deployment started...."
------ Build started: Project: NetduinoApplication1, Configuration: Debug Any CPU ------
NetduinoApplication1 -> C:\Users\......\AppData\Local\Temporary Projects\NetduinoApplication1\bin\Debug\NetduinoApplication1.exe
------ Deploy started: Project: NetduinoApplication1, Configuration: Debug Any CPU ------
Any Idea what went wrong or my netduino fried up somehow? It was working perfectly all right.. Any clues?
(I tried to
1. Restart Machine and deploy
2. Remove and plug in usb again and deploy
but it didnt work)
Vincent
Deployment Problem
Started by VincentA, Dec 26 2010 01:15 PM
Posted 26 December 2010 - 01:15 PM
Posted 26 December 2010 - 08:25 PM
Hi Vincent,
Possible issue #1:
Go into Project Properties > .NET Micro Framework.
Is deployment set to USB? If so, set it to Serial and back to USB and try redeploying again.
Possible issue #2:
Does the blue LED on the Netduino turn off after about 2.5 seconds when you plug it into your PC? If not, it's probably stuck in the bootloader--and you need to erase your current app using MFDeploy.
If neither of those help, please let us know and we'll help troubleshoot further...
Posted 27 December 2010 - 06:29 PM
Sol 2 solved my problem. Could you please elaborate on the issue? why does this happens?
Posted 27 December 2010 - 08:21 PM
That generally doesn;t happen, but it means that something was malfunctioning/corrupted in regards to the .NET MF firmware or your Netduino app. If you can reproduce the issue consistently, we'd love to dig in further.
There are a number of "failsafes" built into .NET MF and the Netduino firmware...
Posted 28 December 2010 - 04:41 PM
I couldnt reproduce this issue. But I've got similar error after previous incident but then simply reconnection netduino and restarting visual studio solved my problems. It happens randomly (might be because I am mostly playing with analog devices?)
Vincent
