Netduino Plus MK2 Debugging (Deployment) issues when piggybacked onto pcb
1 reply to this topic
#1 philvr
philvr
  • 23 posts
  • LocationMelksham, UK
Posted 20 June 2013 - 10:08 AM
When unit is alone I can deploy fine but when I piggyback it onto additional electronics I can not deploy. Consequently I can not debug. Every time I try to debug, Visual C always tries to deploy again and I get a deployment failure. Question 1: Can anyone suggest why I might be unable to deploy when piggybacked onto another pcb? The external circuitry is minimal. It limits the analog and digital voltages to between 0 & 3.3V, it provides 8.6V to the Vin connector and drives a few leds. In theory it ought to be OK...The only worry is that the board will obtain power from Vin while USB is connected for debugging.. Question 2: Are there any alternatives for debugging than USB? Can I use the network, a serial port? or any other type of connection? regards philvr
#2 philvr
philvr
  • 23 posts
Posted 08 November 2013 - 10:12 AM
FYI Issue resolved! (I'm tidying up loose ends on the board) I think using the latest release of the firmware played a significant part, (also I was mixing up some of the assemblies).
