hi,
I'm hoping that someone can help me with what may be a beginners problem...
I have a Netduino Mini on a breadboard. I can ping it and deploy to it via RS232 using a USB-to-serial converter. The mini is running a simple program that blinks an LED, so know that it is working.
I am now trying to deploy via the UART using a new Sparkfun USB FTDI TTL-232 cable – TTL-232R 3.3V cable. I downloaded and manually installed the cable's USB driver, then connected the TX (orange) wire on the cable output connector to pin 12 on the mini and RX (yellow) to pin 11 on the mini.
When I power-on the mini the LCD starts to blink (so I assume its alive). MFdeploy sees that I have a COM7 port, but if I click Ping I get "Pinging... Error: No response from device". Deploying a program from Visual Studio fails.
I have also tried using putty to open a connection to COM7 (115200 bps, no parity, 8 data bits, 1 stop bit, no flow control). The connection seems to open but when I press esc I don't get the "Which transport (1 or 2)?" prompt that I'm expecting.
What am I doing wrong? How can I troubleshoot this? Any advice or pointers would be gratefully received!
Thanks, Andy.
