Motors not working properly - urgent
7 replies to this topic
#1 Ben Harel
Ben Harel
  • 32 posts
Posted 22 May 2013 - 06:36 PM
Hi!
I have a platform(tracked) with two engines. I want to write a simple program that moves the car forward, backward and spin both directions. I used the following circuit, from the netmftoolbox documentation.
http://netmftoolbox....ailable classes
The code doesn't work for me for some reason, the engines do what ever they want.
I am trying to use a code I found on YouTube(modified for my use and the 4.2 version), here is the code:
class Motor
        private OutputPort directionPort;
        private PWM velocityPort;
        private uint velocity;
        private bool direction;
        public const bool Forward = true;
        public const bool Backward = false;
        public Motor(int PWMPortNum,Cpu.Pin pinForDirection)
            switch (PWMPortNum)
                case 3: velocityPort = new PWM(PWMChannels.PWM_PIN_D3, 1000, 0.5, false); break;
                case 5: velocityPort = new PWM(PWMChannels.PWM_PIN_D5, 1000, 0.5, false); break;
                case 6: velocityPort = new PWM(PWMChannels.PWM_PIN_D6, 1000, 0.5, false); break;
                case 9: velocityPort = new PWM(PWMChannels.PWM_PIN_D9, 1000, 0.5, false); break;
                case 10: velocityPort = new PWM(PWMChannels.PWM_PIN_D10, 1000, 0.5, false); break;
                case 11: velocityPort = new PWM(PWMChannels.PWM_PIN_D11, 1000, 0.5, false); break;
                default: velocityPort = new PWM(PWMChannels.PWM_PIN_D5, 1000, 0.5, false); break;
            directionPort = new OutputPort(pinForDirection, false);
            directionPort.DisableInterrupt();
        public void Stop()
            this.Velocity = 0;
            this.velocityPort.Stop();
        public bool Direction
            get { return this.direction; }
            set
                this.direction = value;
                UpdateDirection();
        public uint Velocity
            get { return this.velocity; }
            set
                this.velocity = value;
                UpdateVelocity();
        private void UpdateVelocity()
            velocityPort.DutyCycle = velocity;
            velocityPort.Start();
        private void UpdateDirection()
            directionPort.Write(Direction);
 class DriveSystem
        private Motor leftMotor;
        private Motor rightMotor;
        public DriveSystem()
            rightMotor = new Motor(5, Pins.GPIO_PIN_D4);
            leftMotor = new Motor(6, Pins.GPIO_PIN_D7);
        public void Stop()
            leftMotor.Stop();
            rightMotor.Stop();
        public void SetLeftSpeed(uint speed)
            leftMotor.Velocity = speed;
        public void SetRightSpeed(uint speed)
            rightMotor.Velocity = speed;
            DriveSystem driveSystem = new DriveSystem();
            driveSystem.SetLeftSpeed(100);
            driveSystem.SetRightSpeed(1);
            Thread.Sleep(5000);
            driveSystem.Stop();
            driveSystem.SetLeftSpeed(1);
            driveSystem.SetRightSpeed(100);
            Thread.Sleep(5000);
            driveSystem.Stop();
            driveSystem.SetLeftSpeed(50);
            driveSystem.SetRightSpeed(50);
            Thread.Sleep(5000);
            driveSystem.Stop();
The robot is not moving if I give zero speed value to one of my motors. But the code above only moves one motor(the first) and at the second one - nothing. Only when it gets to the part when both of them should go it - it works.
I am in desperate need of help. I busted my head trying to get it working for the last month, and the project is due tomorrow.(My project is a robot controlled by motion captured from a camera, so I need the robot...)
Thank you
#2 Paul Newton
Paul Newton
  • 724 posts
  • LocationBerkshire, UK
Posted 22 May 2013 - 07:41 PM
Hi Ben,
Looking at the hardware:
There is no power supply shown in the diagram you linked to.
Do you have a Vin supply going to the barrel connector of the netduino (or directly onto the bread board)?
or are you powering the Netduino from 5V USB?
If you only have a 5V input to the Netduino, then I am guessing your motors don't have any power.
The motor driver needs a hefty power supply - I have found its a bad idea to draw power for motors through the Netduino's PCB. I also found it was a bad idea even to share a power supply (unexplained resets).
I now prefer to supply motors with a separate battery pack to the supply for the logic.
In my own buggy I use 6xAA for the motor driver to use, and a separate USB emergency phone charger battery to give 5V for the Netduino.
Looking at the software:
Try something really simple!
Forget PWM, just setup the GPIO as normal ON/OFF outputs and try turning the motors ON, then try reversing them.
This will prove the circuitry works.
Then try replacing the GPIO ON/OFF with PWM.
Hope this helps - Paul
#3 Ben Harel
Ben Harel
  • 32 posts
Posted 22 May 2013 - 08:07 PM
Yes, I connected a power supply to the Netduino.
About the software, I'll try that and report back. Thank you!
EDIT
Wait!
How do I set up the PWM? I gave it 1000 as frequency, is that good?
#4 Ben Harel
Ben Harel
  • 32 posts
Posted 22 May 2013 - 08:16 PM
And how do I reverse the motors? Reversing the cables?
oh I got it
#5 Ben Harel
Ben Harel
  • 32 posts
Posted 22 May 2013 - 10:31 PM
Hi Ben,
Hi.
The left engine for some reason does not work, heres the code:
OutputPort left = new OutputPort(Pins.GPIO_PIN_D4, false);
OutputPort right = new OutputPort(Pins.GPIO_PIN_D10, false);
Thread.Sleep(5000);
right.Write(true);
left.Write(true);
Thread.Sleep(5000);
All of the cables are ok, and if I connect the replace cables between right engine and left engine the left works and the right one is not.
#6 Paul Newton
Paul Newton
  • 724 posts
Posted 23 May 2013 - 05:42 AM
Sounds like the motor circuit is OK, but there is something wrong with the GPIOs. Possibly D4 is damaged. Try again with a different GPIO instead of D4. Then see if you can yet both motors running. I don't have access to my code right now to check the pwm frequency.
#7 Ben Harel
Ben Harel
  • 32 posts
Posted 23 May 2013 - 07:19 AM
I tried D2, still nothing.
#8 Paul Newton
Paul Newton
  • 724 posts
Posted 23 May 2013 - 08:45 AM
Have you enabled the direction contol GPIOs? If you have just left them floating that may be a problem. Enable them or connect to ground to ensure a valid logic level.
