Thanks for responding to my post. Some good things happened today. I have been having trouble with the USB deployement and also running the debugger. I have been seeing posts about using the serial port for deployment so I thought I would spend an hour getting the serial method set up using information from various posts on this forum.
I ran the deployement and oh my gosh it worked like a dream. I used COM1 for deployment and moved my debug COM statements to COM2. No more USB pluging and unpluging and trying 2 or 3 times for the deployment to succeed. I was having problems using 4.2 also. It may have been a wrong driver but I don't know at this time. I had to search the forum for the steps to configure the serial port. I ended up downloading another MFdeploy that Chris had mentioned. I did not see the Serial configuration screen in the latest MFDeploy 4.3.
The deployment was working great so I thought I would try the debugger and WOW, It worked great. I get the deployment succeeds message and new messages that the symbols are loading.
One other thing I need to put out there in case people have problems with the emulator. There is a setting in the propertes where we select the CPU that we are running on. I had a choice to select to run on Any CPU or x86. I switched to x86 and the emulator started working great.
I am going to use this setup for my current project but if anyone wants me to try a test, I will use one of my other Netduino Plus 2 boards to set up the test.
To recap my setup:
Windows 7 64 bit
Micro Framework 4.3
SDK 4.3
Firmware 4.3 Beta
Dave
