Best Answer Paul Newton, 28 March 2013 - 06:21 PM
Hi, Welcome to the forums. Modems have a number of parameters that can be set by sending AT commands. On devices I have used in the past, this has included echo of commands that you type. So it is possible that you have turned off the echo. In the first instance, try checking the modem's manual for available commands. I used to know quite a few command off by heart, but have not had to use them for a few years now A complete guess try ATE=1 Hope this helps -Paul EDIT Did a quick google search: ATE1 for echo ON and ATE0 for OFF. Go to the full post
