Hello,
I've been able to implement all display and touch functions on the nwazet touchscreen display, including implementing event listeners to react to specific screen touch areas. I've successfully accessed the file system on the DAQ and read and written to files. What I can not seem to figure out is how to make the displayBitmapImage call recognize a filename from an SD card on the daq. The daq file access method uses an integer fileId when accessing files on the daq. The displayBitmapImage call for the touch display take a string filename. I can not determine any way to make the touchscreen procedures recognize the daq file system. I can write to the display from the daq using a buffer, and displayBitMapRaw, but do not want to have to access the headers, set my own offsets, and determine values for displaying from a loop of direct buffer transfers, if there is a way to have the simpler method access my daq file directly.
Does any one know a way to send bitmap files from the daq to the displayBitmapImage routine for the touchscreen, or is the only way to display bitmaps from the daq to use the displayBitmapImageRaw routine? I would really love for someone to tell me I've made a newbie mistake, and have totally misunderstood this situation and there is a simple way to do what I want to do.
