For some reason this only works once. I am debugging on RS232 and have an XBee connected to TTL. In the code I open up COM2 to read data from the XBee. If I stop debugging and then start again I can't. I cannot even connect via MFDeploy. At that point I have to reflash TinyBooter and the firmware to get the Netduino Mini working again.
Not sure if it's just me, but fyi.
phantomtypist,
Do you have any more info on this? That should not happen at all.
BTW, you can force your Netduino Mini into bootloader mode (so that you can erase your current app) by applying power to the DTR pin (pin 3) during power up. No need to erase and reflash.
