Uploading code without VS?
uploading code coding flashing
10 replies to this topic
#1 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 28 February 2013 - 05:15 PM
Is there a way to upload a compiled project without going through Visual Studio? Specifically, I'm wondering if it's possible to write a small program in C# that will connect to the Netduino and upload pre-compiled code. How would I accomplish this?
#2 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 28 February 2013 - 05:55 PM
This is what MFDeploy can do however you are not deploying the compiled program.  You are uploading an image (hex file) of the program as it is on the Netduino.  I don't believe there is a way to build a deployment utility without getting into the working of how Visual Studio deploys.  If you are able to deploy your software to a Netduino, you can use MFDeploy to copy that code to a .hex file and using MFDeploy you can easily deploy this hex file to many Netduinos in essence creating clones from the image.  I believe this is your only solution.
#3 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 28 February 2013 - 08:20 PM
Any solution is a good solution. How do I go about making a hex file? Also, isn't it possible to call the MFDeployEngine from any .NET program?
#4 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 28 February 2013 - 08:54 PM
Yes you can call the engine which allows you to use the functionality.
To create your .hex file, deploy your working code to your Netduino, then run MFDeploy and connect to the Netduino.  Then go to Target > Application Deployment > Create Application Deployment and simply enter the path and create the hex file.
You then can use MFDeploy or the Engine via code to deploy the Hex file to a Netduino.
#5 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 28 February 2013 - 11:53 PM
Create Application Deployment hangs indefinitely at 99%. How to get around this? I've tried both creating a key and not creating a key.
#6 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 01 March 2013 - 02:58 AM
Hmmmm, I've used this many times and it worked fine.  I'll give it a try tomorrow and see if something changed.  Are you using a Netduino or Netduino 2?
#7 Chris Walker
Posted 01 March 2013 - 03:15 AM
Hi Verdris, What version of firmware do you have on your Netduino? What version of MFDeploy (i.e. what version of the .NET Micro Framework SDK)? Chris
#8 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 01 March 2013 - 07:27 PM
Netduino Plus 2 with 4.2.2 firmware running .NETMF 4.3.
#9 Chris Walker
Posted 01 March 2013 - 10:23 PM
Hi Verdris,
Ah, that's probably the issue. There are some known timing issues with MFDeploy 4.3 when used with boards running earlier firmware.
Here are a few recommendations:
Option 1:
Update your Netduino to 4.3 beta 1 firmware
Option 2:
Grab our custom copy of MFDeploy 4.1. It will somewhat-coincidentally work with your Netduino Plus 2.
http://forums.netdui...b-and-com1com2/
Do either of those resolve the issue for you? [If you're using these for production purposes...I would recommend option 2.]
#10 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 01 March 2013 - 11:15 PM
Hi Verdris,Ah, that's probably the issue. There are some known timing issues with MFDeploy 4.3 when used with boards running earlier firmware.
Option 1:
Option 2:
Option 2 worked. How often is the custom MFDeploy updated, and where should I watch for it?
#11 Chris Walker
Posted 02 March 2013 - 01:15 AM
Hi Verdris,
Okay, great. Glad that you're off and running now. The custom MFDeploy was created for a special use case scenario, so it's not something that's regularly updated. I refer you to it just because it happens to also take care of the issue you were experiencing with MFDeploy 4.3. Chris
Also tagged with one or more of these keywords: uploading code, coding, flashing
