I2C netduino plus 2
I2C netduino plus 2
Best Answer JohanV, 22 January 2014 - 02:42 PM
Sorry for the late reply,
the (I2C) ND2+ works without a problem ( off course ).
Like Dave told here.
I was using false pull up resistors.
thanks
15 replies to this topic
#1 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 07 February 2013 - 11:42 PM
I have a small test project running on the netduino plus.
( so any hardware or pull-up etc is ok )
and want to test it as well on the netduino plus 2.
the problem is the execute methode returns always 0 ( zero )
the divice address is 27 or (0x1B)
            for (address = 0x00; address < 126; address++)
                I2CDevice.Configuration config = new I2CDevice.Configuration(address, 100);
                var n = I2CBus.Execute(config, 25, I2CBus.CreateWriteTransaction(new byte[] { 0xAC, 0x00 }));
                Debug.Print("INIT(" + address.ToString() + ")=" + n.ToString());
the n var always gives 0, ( on the netduino plus 2. )
on the netduino plus this gives an 2 when found.
and 1 when there is no device.
i have tried some things from the forum, also updating the netduino 2.
( that turned out to be quite easy )
But no luck.
#2 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 10 February 2013 - 09:57 AM
I also found with nothing connected on the netduino plus 2 board,
the i2c. execute always return 0
the old netduino plus with nothing connected always return 2.
any ideas ?
thanks
Johan
#3 yogotie
yogotie
  • 16 posts
Posted 10 February 2013 - 03:29 PM
I had the same results when experimenting with pullups and the I2C bus locking issue.  If there was nothing there and no pullups then the bus got into a locked state, always returned 0.
Interestingly enough the arduino uno r3 hardware does not have this problem.
#4 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 10 February 2013 - 04:16 PM
Have you upgraded your ND+2 to the latest firmware with the I2C fixes?  Is this one of the things you tried?
#5 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 12 February 2013 - 03:28 PM
Hi Dave / Yogotie,
I realy hope to get this solved.
I'm struggeling for a week now with this.
I also read on a form the new ND2+ does not need pullups ?
Yes i updated the firmware, [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Version: 4.2.2 Update 2 (version 4.2.2.2)[/color]
http://forums.netdui...-v422-update-2/
-> i used the new SDA SDL connectors that should be ok ?
-> tried 3,3 and 5,0 Volts.
-> i have 1,2 Kb pullups  ( http://www.dsscircui...-resistors.html )
also the external reference: ( tried both )
SecretLabs.NETMF.Hardware.NetduinoPlus.dll ( 07-01-2013 )
SecretLabs.NETMF.Hardware.Netduino.dll  ( 27-10-2012 )
i think it should be newer file ?
The board is REV.A ?
should i change the pullups ? to 10k ?
I have 2 x DS2482 on the I2C bus. and this was quite ok, with the older ND1+.
Pinging... TinyCLR
HalSystemInfo.halVersion:               4.2.0.0
HalSystemInfo.halVendorInfo:            Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC
HalSystemInfo.oemCode:                  34
HalSystemInfo.modelCode:                177
HalSystemInfo.skuCode:                  4102
HalSystemInfo.moduleSerialNumber:       00000000000000000000000000000000
HalSystemInfo.systemSerialNumber:       0000000000000000
ClrInfo.clrVersion:                     4.2.0.0
ClrInfo.clrVendorInfo:                  Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC
ClrInfo.targetFrameworkVersion:         4.2.0.0
SolutionReleaseInfo.solutionVersion:    4.2.2.2
SolutionReleaseInfo.solutionVendorInfo: Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC
SoftwareVersion.BuildDate:              Jan 26 2013
Any help would be great.
#6 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 12 February 2013 - 04:20 PM
Also i found this in a post, from Mr Walker.
So the NetDuinoPlus.dll should be removed.
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]In the meantime, if you are upgrading your Netduino Plus 1 projects to Netduino Plus 2:[/color]
    [*]Remove the SecretLabs.NETMF.Hardware.NetduinoPlus.dll reference from your project.
    [*]Add the SecretLabs.NETMF.Hardware.Netduino.dll reference to your project
    [*]Change the deployment target in Project Properties > .NET Micro Framework
    [/list]
#7 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 12 February 2013 - 04:27 PM
for the pullups: id suggest using 4.7 kilo-ohm - that worked great for me.
when adding more devices you can lower that, but from my experience most modules have allready pullups included
i havent changed my 4.7k so far, and iam using like 5 devices on the i2c bus
#8 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 12 February 2013 - 05:02 PM
To be sure. did you use the new SDA / SDL connectors ?
I try tonight to change the resistors. hope it will be solved.
thanks
#9 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 13 February 2013 - 09:19 PM
I have tried 1 and 2 devices and also the 4,7K  2,2K and 10K.
but no luck yet. the execute method still gives zero.
could it be a Rev.A issue ? of the netduino plus 2 ?
#10 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 13 February 2013 - 09:53 PM
I have not experienced any issues with ND+2 and I2C devices.  I have dozens of different I2C devices and all work fine on the ND+2.  All are using the proper Pullup Resistors and all are connected to the SDA and SCL lines not A4 & A5.  All of my boards are running the 4.2.2.2 firmware.
I still believe its an issue with your software or hardware wiring.
#11 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 14 February 2013 - 09:12 PM
My software and hardware works fine. on diferent boards as well.
also on the old NetDuino Plus (1).
this same problems i have is also on the STM32F4 Discovery.
Dave, could you test this small piece of code ? on your I2C bus ?
On the old netduino it returns a 2 and a 1 if it finds an I2C device.
thanks
#12 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 14 February 2013 - 09:31 PM
Hi Dave,
your idea, could be right it could still be software.
i was thinking if it runs on the old netduino it should also run on the netduino 2.
thanks
#13 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 14 February 2013 - 11:10 PM
Hi Dave,
thanks
In the beginning of the ND+2 release, there were known I2C issues with the earlier firmware but that has been resolved.  The only difference is the dedicated SDA and SCL pins.  I was able to easily transfer everything I had from ND+ to ND+2 and just move the two I2C wires on my shield from A4/A5 to SDA/SCL and everything ran like it always did.
I'll fire up one of my backup ND+2's tomorrow and test the code.  I will let you know what I find in about 24 hours from now.
#14 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 18 February 2013 - 06:17 PM
New Update,
i have been checking the I2C signal, on the old ND+ i get 3,3 and 0 signals or 5volt/0 volt on the
I2C wires.
with the same hardware on the ND2+ the I2C signal is not pulled down to 0volt correctly.
the ND2+ is trying to communicate. it's like the signal is floating a bit.
any idea how to solve this ?
#15 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 19 February 2013 - 12:22 AM
I down graded the firmware to 4.2.1.1, and got the ND2+ sending some signals again on the I2C bus.
but the software I2C execute still give zero.
#16 JohanV
JohanV
  • 21 posts
  • LocationAmsterdam
Posted 22 January 2014 - 02:42 PM   Best Answer
thanks
