Blown Netduini Plus2
7 replies to this topic
#1 Russ Black
Russ Black
  • 4 posts
Posted 04 February 2013 - 08:43 PM
Have blown a n+2 by connecting to a car battery via 12v->9v inverter.
Just found out why: the inverter was wired the wrong way around 12v into the 9v output port and vice-versa.
Is there likely to be anything salvagable for the n+2. i.e. any bits that would have blown / can be replaced?
many thanks
Posted 04 February 2013 - 08:47 PM
Hi Russ, ;( Many of the parts on your Netduino Plus 2 are probably okay, if you want to scavenge. I would avoid trying to replace parts on the board...although you're certainly welcome to. Which pins did you connect the external power to? There is some reverse voltage protection on Netduino Plus 2 but the creative types can still electrocute a board if they really want to. D: Chris
#3 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 04 February 2013 - 10:49 PM
you sure it blew up the duino?
more likly the converter is dead. the netduino can survice 12v. except you connect gnd to vin and positive to
to gnd-in -> that will fry your on board voltage converter and maybe the netduino chip itself
#4 Mario Vernari
Posted 05 February 2013 - 04:31 AM
I agree with Noom, your board should be still alive.
Noom is mistaking just a thing: both the Netduino (old) and Netduino 2 are inversion protected.
#5 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 05 February 2013 - 08:08 AM
yeah, someone should buy me a plus2 so i get familiar with those too :P
my mini isent protected like that :(
#6 Russ Black
Russ Black
  • 4 posts
Posted 05 February 2013 - 08:14 PM
Definatly something is gone in it, can't power it up via usb or wall wart.
When I said the wrong way around i didn't mean polarity, it was inverter output was connected to the 12v battery & the n+2 to the input.
I think my multi-meter is playing up as it says my (bike) battery is outputing 24v.
Was just asking in case  there was a fuse / power regulator on the board that could be replaced.
Sounds like not.
#7 Chris Walker
Posted 05 February 2013 - 08:17 PM
Hi Russ,
Was just asking in case  there was a fuse / power regulator on the board that could be replaced. Sounds like not.
The most likely part to be damaged is your switching regulator or its associated components. If you take a look at the schematic and board design files, you can see how it's all connected. You're certainly more than welcome to try to replace the blown parts yourself...that would be some fun hacking. My bigger concern is that you might have some other damaged parts; if you go the repair route you'll want to analyze the power in and power out of each section in the schematic. Chris
#8 Russ Black
Russ Black
  • 4 posts
Posted 07 February 2013 - 10:03 PM
thanks for all your help.
new one arrived today so I'm back up and running.
I might have a look at the blown one again at some point.
Will definatly double check the regulator power output before i connect it up again.
and maybe test it with an old Arduino first ;)
