I got my Mini last week, and since i didn't have an RS232 adapter at the time, I switched the deployment port over to the TTL port as described on the forums here.
Now that I have an RS232 adapter, I want to switch back to the default, but I can't seem to get to the menu to switch it back.
At the moment I have both ports accessible using Putty, and using a test app, verified that both are able to send/receive data.
What do I have to do to switch back to RS232 deployment?
-Brandon
Need help switching back to RS232 deployment
Started by Brandon, Dec 03 2010 05:48 PM
5 replies to this topic
Posted 03 December 2010 - 05:48 PM
Posted 03 December 2010 - 08:31 PM
Hi Brandon,
For now, run the attached "Netduino Mini Transport Selector" program on your Netduino Mini. Connect through a serial port terminal program as before...and select the RS232 port instead.
EDIT: attachment moved to latest Netduino Mini firmware post.
Posted 04 December 2010 - 12:39 AM
That worked! Thanks a lot for your help. Now I can wire up the XBee!
-Brandon
Posted 07 December 2010 - 05:20 PM
I ran the "Netduino Mini Transport Selector" but it is not giving the option at start up.
On the TTL UART I get the startup text
Attaching file.
Assembly: SecretLabs.NETMF.Diagnostics (4.1.0.0) (180 RAM - 440 ROM - 166 METADA
TA)
Attaching deployed file.
Assembly: NetduinoMiniTransportSelector (1.0.0.0) (244 RAM - 1168 ROM - 310 META
DATA)
Resolving.
Total: (8784 RAM - 75260 ROM - 41862 METADATA)
Ready.
How do I get the option to display again?
Posted 07 December 2010 - 06:29 PM
The menu will appear on the RS232 port by hitting ESC.
Posted 07 December 2010 - 06:39 PM
Right got it. I was hitting the escape on the TTL UART terminal.
Thank you Brandon.
