How can I find address of TinyCLRs
tinyclr memory address
1 reply to this topic
#1 jiwonoh
jiwonoh
  • 42 posts
Posted 24 January 2013 - 02:54 AM
Dear,
I want to modify my own firmware source. I'm using GCC4.6, and it works.
Compiler spilt out er.config.bin & er.config.bin, then convert it to .dfu format using DFU File Manager.
In the DFU tool, I have to fix the memry address for er_config, er_flash.
If I want to adjust the memory map to fit my system. Which files or variables are related with?
I found some variables are defined in STM32_template_selector.h such as FLASH_MEMORY_Base.
Thanks, from Jiwon.
Posted 24 January 2013 - 04:00 AM
Hi Jiwon, You'll configure your block layout in: C:MicroFrameworkPK_v4_2Solutions[solution]DeviceCodeBlockstorageSTM32STM32_BlConfig.cpp And then update the scatter files in the solution's TinyBooter and TinyCLR directories to match. Finally, once you build your firmware you can verify the addresses and sizes of each file. To do so, just load the HEX files into MFDeploy and it'll show you the starting address and length next to the files. You can also verify that the flash layout of your board matches after you've flashed the firmware by selecting "flash layout" from the plug-ins menu in MFDeploy. Chris
Also tagged with one or more of these keywords: tinyclr, memory address
