Hi Support,
I have set the debugger to COM1 using mfdeploy on the Netduino Plus 2 to program in VS via COM1
I have Deployed the Sample HID keyboard code, originally wrote for the Netduino. When debugging it appears that the USB controller and USB device are starting, but Device manager always shows Netduino.
I have deployed, and rebooted the device and still the same.
I have also tried to use a 7.5 V power supply to power the board, however I cannot program via serial unless the Netduino Plus is connected via USB to the same PC, and external power is disconnected. Im not sure why powering the board would prevent programming.
Are USB devices currently supported? Is there any issues with programming with external power?
Thanks again for your support,
endo
