Unexpected Error when leaving DFU Netduino plus 2
6 replies to this topic
#1 endo
endo
  • 14 posts
Posted 22 January 2013 - 04:51 PM
 Hi Support,
I have attempted to install the NetduinoPlus2_Firmware_4.2.2.0.dfu firmware release and
am unable to recover after flashing.
These are my steps.
1. Using DFU Flasher select protocol and Create Empty. Next I selected Erase and Go
2. In dfuSe Demo v 3.0 I select verify after download and choose the above DFU file
It programs ok and verifies. When I press Leave DFU it gives me an error at 49%
->Error Code Unexpected error
Operation: Return
Transfer size: 2048
DFU STate: State DFU_IDLE
DFU Stauts: STatus_OK
Request: Awating UNPLUG EVENT
CurrentNBlock: 0x000
CurrentLength: 0x000
Percent 49%
When rebooting the Netduino is not detected. I can only get into DFU mode at this point.
This is happening on both of my new boards. Please advise.
Thanks.
endo
#2 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 22 January 2013 - 05:28 PM
Hi endo,
To erase your Netduino Plus 2 you need to do the following:
1. Detach your Netduino 2. Press and hold your Netduino's pushbutton while plugging it in via USB; this will put it in bootloader mode. 3. Erase the firmware on your Netduino using the STDFU Tester application > a. Select the "Protocol" tab > b. Press the "Create from Map" button > c. Select the "Erase" radio button option > d. Press the "Go" button > e. Wait for erase process to complete
In your description you are using "Create Empty" and it should be "Create from Map".
Once the erase procedure has completed close the STDFU Tester applicaiton and open up DfuSe Demonstrator without unplugging your Netduino. Then follow these instructions laid out by Chris:
4. Flash the attached .DFU file using the ST DfuSe Demonstrator application (included with STDFU Tester) > a. Locate the "Upgrade or Verify Action" pane (bottom-right pane) > b. Press "Choose..." and select the attached DFU file > c. Check the "Verify after download" option > d. Press "Upgrade". It will take a few minutes to update your Netduino. > e. Detach and reattach your Netduino (power cycle) or press "Leave DFU mode"
This should work smoothly but just make sure you don't quit the DfuSe Demonstrator application until the process is complete.
Hope this helps.
Steve
#3 endo
endo
  • 14 posts
Posted 22 January 2013 - 05:56 PM
I selected create from MAP and erased again.
Same ERROR after programming with the NetduinoPlus2_Firmware_4.2.2.0.dfu
I am using DfuSe_Demo_V3.0_Setup.exe for the programming. Is that correct?
#4 endo
endo
  • 14 posts
Posted 22 January 2013 - 07:34 PM
I have followed the exact steps several times, is there anything else to get this up and running?
endo
#5 Chris Walker
Posted 22 January 2013 - 07:37 PM
Hi endo,
Are you using Dfuse 3.0.2 or 3.0.0? Here's the link to 3.0.2:
http://www.st.com/in...DEMO/um0412.zip
#6 endo
endo
  • 14 posts
Posted 22 January 2013 - 07:53 PM
Sweet! working like a champ! Note: DfuSe v3.00 does not work.
#7 howard_li
howard_li
Posted 27 January 2013 - 04:16 PM
Same problem. Thanks all of you.
