Best Answer ash, 11 January 2013 - 03:41 PM
sorry stefan. can you delete this thread please
I managed to get to work by setting the hardware to the emulator then the plus 1
Go to the full post  | ||||||||||||||
Error 7 Device not found or cannot be opened - USB:Netduino
Started by ash, Jan 11 2013 03:24 PM
I managed to get to work by setting the hardware to the emulator then the plus 1 Go to the full post
#1Posted 11 January 2013 - 03:24 PM the project is not working on the plus 2 so im trying to deploy the project back to plus 1 and i cant why is it? does this mean its not backward compatible. Also how do i support legacy systems? #2Posted 11 January 2013 - 03:25 PM Hi Ash,
As I just explained in your other thread, the NP1 is still for sale. Also, a NP2 app should also be able to run on a NP1 (with as limitation the added features of course).
But if you swap the device, you also need to go back to your project properties and specify the target device.
My .NETMF projects: .NETMF Toolbox / Gadgeteer Light / Some PCB designs #3Posted 11 January 2013 - 03:41 PM Best Answer sorry stefan. can you delete this thread please
I managed to get to work by setting the hardware to the emulator then the plus 1 #4Posted 11 January 2013 - 04:28 PM
Hi ash,
On supporting legacy systems...Netduino Plus 1 and Netduino Plus 2 are both in volume production. Demand for both boards is high so I know that supplies of both have been tight the last two months. Some resellers like to carry only the latest and greatest hardware, but when you need gen1 or gen2 boards we can point you to a reseller that has them in stock--or get you a lead time to let you know when the next ones are coming off the assembly line. As a bonus, Netduino Plus 1 boards are now just $49.95...so they're even more affordable than before.
On deployment...you found the issue. When switching deployment between boards with different names (such as NetduinoPlus and Netduino), you will need to switch the "deployment target" in Visual Studio (in "Project Properties > .NET Micro Framework"). The gen2 boards are called simply "Netduino" vs. "NetduinoPlus" for gen1.
Due to the way the dropdown box works in that Visual Studio dialog, in these cases you may need to switch the transport from USB to Serial or Emulator...and then back to USB. While the dropdown box may show the name of your currently plugged-in board, Visual Studio can't register the new board name until the selection is physically changed. It's an odd issue, and it's the one Visual Studio issue we've wished could be fixed for a few years now...but it is apparently fairly tough to tweak. With the Netduino 4.2.2 firmware...we've started using the USB Name of "Netduino" on all boards (Netduino, Netduino Plus 2, and Netduino Go). This should make it even easier to deploy the same project to multiple boards...without needing to mess with the project settings.
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
