Best Answer Chris Walker, 11 January 2013 - 04:35 PM
Hi bramVD,
It looks like you're using a library which requires .NET MF 4.1. But your board has .NET MF 4.2 on it. With the desktop .NET framework, you can include .NET 3.0 assemblies in a .NET 4.0 application. But with .NET Micro Framework, the assemblies all need to be compiled for the same version of .NET Micro Framework. This is one of the reasons why .NET code can fit on these tiny micros. The NETMF runtime is stopping your program from running, due to the version mismatch. Otherwise you'd get unexpected and invalid operations. Do you have a copy of the library built for .NET MF 4.2? Chris Go to the full postOke, did the Reboot CLR and Ping, this is the result:
Assembly: MicroLiquidCrystal (1.1.0.0)Attaching deployed file. needs assembly 'Microsoft.SPOT.Native' (4.1.2821.0) Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0)
