This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) and Netduino 4.2.2 SDK.
192KB Flash
60KB RAM
1. Now compatible with legacy SecretLabs AnalogInput and PWM classes (requires 4.2.2 SDK)
2. Bug fix: SPI chip select timing corrected
3. Bug fix: PWM frequency corrected
4. New: more reliable rebooting during deployment
To flash this firmware:
1. Detach your Netduino
3. Erase the firmware on your Netduino using the STDFU Tester application
> d. Press the "Go" button
4. Flash the attached .DFU file using the ST DfuSe Demonstrator application (included with STDFU Tester)
