Given that there are I2C problems in the original firmware I would suggest that you upgrade to the latest firmware as per the update article. It's not too difficult and only takes five minutes or so.
At least by doing this you know that any issues are less likely to be firmware related.
Totally nailed it Mark. I thought I was at latest firmware but I was wrong and boy that is the big difference. THanks!
Erm, basic documentation like here? http://netmftoolbox....ailable classes
I have planned to do a small video tutorial too by the way.
The shield should work fine with a NP2. The only issue I am aware of is that, after some period, characters can become scrambled.
But that's not what you describe.
Please try that sample code, that should work.
-edit- Mark has a point, you'll need the latest Netduino Plus 2 Firmware.
Stefan - Thanks much for all the work and examples into the toolbox - didn't mean to criticize. I saw your video on "how to install" and that was very simple in terms of running the installer, then I had to go find:
http://netmftoolbox....se the classes?, which for some reason as a n00b I found just a bit trickier to stumble on from the docs page. And since I knew if I was going to VB I needed to use the DLL's, I looked at that part which talks about using a zip file for the DLL's. I was pretty sure that was obsolete and that the Windows installer program had already installed them for me (which of course it had) so then I just had to go back and re-run the installer and actually pay attention this time to what path it was using... once I had that path so I knew where the DLL's were dumped, I could add the references easily.
And then the VB code example for this particular item didn't explicitly show the Imports line - I just found another VB example with it... I had seen the link you reference but wanted to be sure I had the Import name correct - as I said found plenty of examples with a little poking around.
As above - working great now! Just wrote some profanity to my display. Works great! Thanks again for the work on the Toolbox. Super cool resource.
