CIRC-06 | Music With Piezos Netduino Plus 2 MS Port
Best Answer qsnapper, 07 January 2013 - 09:17 PM
If anyone having the same issue, the below is the updated working code for Microsoft.SPOT.Hardware.PWM
using System;                               //use base classes                            using System.Threading;                     //use threading classes        using Microsoft.SPOT;                       //use smart personal objects technology classesusing Microsoft.SPOT.Hardware;              //use hardware related SPOT classesusing SecretLabs.NETMF.Hardware;            //use Secret Labs hardware frameworkusing SecretLabs.NETMF.Hardware.Netduino;   //use the Netduino specific classesnamespace Piezo{    public class Program    {        //static PWM speaker = new PWM(Pins.GPIO_PIN_D9);  // Add the following line instead of this one        static PWM speaker = new Microsoft.SPOT.Hardware.PWM(PWMChannels.PWM_PIN_D9, 100000, 0.5, false);        static char[] notes = "ccggaagffeeddc ".ToCharArray();        static int[] beats = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 };        static int tempo = 300;        public static void Main()        {            speaker.Start();        // Add this            while (true)            {                for (int i = 0; i < notes.Length; i++)                {                    playNote(notes[i], beats[i] * tempo);                    playNote(' ', tempo / 2);                }            }        }        /// <summary>        /// Plays a particular tone for a particular duration        /// </summary>        /// <param name="tone">The tone to play</param>        /// <param name="duration">How long to play the tone</param>        static void playTone(int tone, int duration)        {            //speaker.SetPulse((uint)(tone * 2), (uint)tone);     //Uncomment this nad use the next two lines instead            speaker.Period = (uint)tone * 2;            speaker.Duration = (uint)tone;            Thread.Sleep(duration);                             //waits the appropriate amount of time        }        /// <summary>        /// Looks up the tone for a note based on it's letter and plays        /// it for a specific amount of time        /// </summary>        /// <param name="note">The letter of the note to play</param>        /// <param name="duration">How long to play the tone</param>        static void playNote(char note, int duration)        {            char[] names = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C', ' ' };    //The array of possible notes            int[] tones = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956, 0 };//The frequency of each note in the previous array            for (int i = 0; i < 9; i++)     //Goes through each note            {                if (names[i] == note)                {                    playTone(tones[i], duration); //Plays the right note                }            }        }    }}
#1 Jean-Martin
Jean-Martin
  • 18 posts
  • Location[FR], Montreal, Canada
Posted 05 January 2013 - 10:41 AM
Edited: to the right Version of the script. Jean-Martin
Jean-Martin
#2 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 05 January 2013 - 01:28 PM
id change it for normal microsoft pwm class. very easy to port.
#3 qsnapper
qsnapper
  • 8 posts
Posted 07 January 2013 - 09:17 PM   Best Answer
#4 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 07 January 2013 - 11:22 PM
good job! :)
#5 Jean-Martin
Jean-Martin
  • 18 posts
Posted 08 January 2013 - 12:57 AM
Haha thank to the Chat guy !!!
Jean-Martin
