Easiest way to use QS30-1 Nixie Tube Module?
Best Answer remotewizard, 08 September 2013 - 07:20 PM
I put this aside until I got caught up on other projects, and finally took another look.  Turns out that using SPI to send data to the Nixie tubes was trivial, and using PWM to control the brightness was even more so!
Thanks again!
Go to the full post
9 replies to this topic
#1 remotewizard
remotewizard
  • 96 posts
Posted 26 December 2012 - 08:24 PM
I was lucky enough to have Santa bring me four QS30-1 Nixie tube modules (http://www.dfrobot.c...&product_id=738) for Christmas.  Given my (admittedly sketchy) understanding of the design, it appears that each module is can be trated like a virtual 74HC595 (actually, each module contains two 74HC595s, but I digress), with the ability to easily daisy chain multiple QS30-1s.  The provided Arduino library can be found at http://www.dfrobot.c...ieTube v1.2.zip, while the schematic is at http://www.dfrobot.c...atic_Prints.pdf.
Could I simply attach the modules using SPI (e.g. Nixie OE to Netduino D10, Nixie Din to Netduino D11, Nixie SHCP to Netduino D13, and ground to ground) and use something like the Ic74HC165 module in the netmftoolbox?  If so, could I use PWM on D10 to control brightness (they recommend not running the tubes at full brightness to prolong their lives) while simultaneously using the Ic74HC165 module?
Or have I completely misunderstood the way the QS30-1 works?
#2 Mario Vernari
Mario Vernari
  • 1768 posts
  • LocationVenezia, Italia
Posted 27 December 2012 - 04:58 AM
Make sure any of the boards (Netduino and the nixie's) are powered off.
Refer to the schematic and consider only the D-IN connector.
First of all, ensure a very good ground: the Netduino's and the board should be wired together, possibly with a short yet good connection.
Tie the OE (5) input to the ground: that is the main enabling for any segment and led on the board.
Connect D_IN (6) to the Netduino MOSI pin, SHCP (2) to the Netduino SCLK, and the STCP (4) to any Netduino output port.
Check all the wiring once again, then try to power the boards.
NOTE: the nixie requires about 160V for lighting up, thus you should *avoid* putting fingers on the circuit when it's powered. Also a wrong wiring could damage permanently the Netduino.
You can use any 74HC595 oriented code/library: the board uses those chips, not the 74HC165.
#3 remotewizard
remotewizard
  • 96 posts
Posted 27 December 2012 - 01:18 PM
Exactly what I was hoping to find.  Thank you.
So I shouldn't try to use PWM on OE to set the duty cycle (and thus the brightness)?
#4 Mario Vernari
Mario Vernari
  • 1768 posts
Posted 27 December 2012 - 01:40 PM
Sorry, I totally missed your question on that!
Well, it's a good point: it's correct that you may enable/disable the whole board by using the OE signal, but I'm not sure you could use the PWM for a nixie. I never tried it...you might try!
Just in case, try with a very low frequency: let's say 100Hz or so.
#5 remotewizard
remotewizard
  • 96 posts
Posted 27 December 2012 - 02:26 PM
I'll do that and post my results.  Thanks again!
#6 remotewizard
remotewizard
  • 96 posts
Posted 08 September 2013 - 07:20 PM   Best Answer
Attached File  7654-small.JPG   116.39KB   1 downloads
Thanks again!
#7 n0rb
n0rb
  • 2 posts
Posted 09 September 2013 - 03:45 PM
hey remotewizard!
would you be so kind and post your schematics and code :D ?
I got the same nixie tubes and ported the arduino library to c#.
almost everything is working ... except I cannot display 0 (zero) and cannot control the brightness :/
I would really appreciate it for my nixie kitchen clock project :D
#8 remotewizard
remotewizard
  • 96 posts
Posted 24 October 2013 - 08:26 PM
Sorry - I only just saw this now.  I'll try to dig out the info over the weekend and post it ASAP.
#9 remotewizard
remotewizard
  • 96 posts
Posted 26 October 2013 - 07:36 PM
Back again!  Please note that my connection information is from handwritten notes; you'll want to double-check the DFRobot documentation before actually trying this out.
I daisy-chained all four Nixie modules together, then connected an external 12V supply to pins 7 and 9.  I then connected:
Pin 1 (DIN) => Netduino pin D11
Pin 2 (ST)   => D8
Pin 3 (SH)   => D13
Pin 4 (OE)   => D5
Pin 5 (GND) => ground
Pin 6 (+5)   => +5
I haven't got as far as writing a proper class just yet; this is more of a proof-of-concept.
namespace NixieTest2{    public class Program    {        public enum Color        {            White,            Yellow,            Cyan,            Green,            Magenta,            Red,            Blue,            Black        };        public enum Colon        {            None,            Upper,            Lower,            Both        };        public static void Main()        {             OutputPort ChipSelect = new OutputPort(Pins.GPIO_PIN_D8, false);             PWM BrightnessControl = new PWM(PWMChannels.PWM_PIN_D5, 1000, .5, true);             BrightnessControl.DutyCycle = .5;             BrightnessControl.Frequency = 1000;             BrightnessControl.Start();            var spiConfig = new SPI.Configuration(                SPI_mod:  SPI.SPI_module.SPI1,                             ChipSelect_Port: Cpu.Pin.GPIO_NONE,                ChipSelect_ActiveState: false,                ChipSelect_SetupTime: 0,                ChipSelect_HoldTime: 0,                                Clock_IdleState: true,                Clock_Edge: true,                Clock_RateKHz: 1000                );           SPI Spi = new SPI(spiConfig);           ushort[] bufOne = new ushort[1];           ushort[] bufTwo = new ushort[1];           ushort[] bufThree = new ushort[1];           ushort[] bufFour = new ushort[1];           bufOne[0] = 0;           bufTwo[0] = 0;           bufThree[0] = 0;           bufFour[0] = 0;            ChipSelect.Write(false);            Thread.Sleep(20);                         Spi.Write(bufOne);            Spi.Write(bufTwo);            Spi.Write(bufThree);            Spi.Write(bufFour);            ChipSelect.Write(true);                        Thread.Sleep(20);            ChipSelect.Write(false);            Thread.Sleep(20);            //common color and colon stuff            int ColorAndColon1 = ((int)Color.Red << 4) + ((int)Colon.Upper << 2);            int ColorAndColon2 = ((int)Color.Cyan << 4) + ((int)Colon.Lower << 2);            int ColorAndColon3 = ((int)Color.Yellow << 4) + ((int)Colon.Both << 2);            int ColorAndColon4 = ((int)Color.Magenta << 4) + ((int)Colon.None << 2);            //write '7654'            bufOne[0] = (ushort)ColorAndColon1;            bufOne[0] <<= 8;            bufOne[0] |= 64;            bufTwo[0] = (ushort)ColorAndColon2;            bufTwo[0] <<= 8;            bufTwo[0] |= 32;            bufThree[0] = (ushort)ColorAndColon3;            bufThree[0] <<= 8;            bufThree[0] |= 16;            bufFour[0] = (ushort)ColorAndColon4;            bufFour[0] <<= 8;            bufFour[0] |= 8;            Spi.Write(bufOne);            Spi.Write(bufTwo);            Spi.Write(bufThree);            Spi.Write(bufFour);            ChipSelect.Write(true);            Thread.Sleep(Timeout.Infinite);        }     }   }
#10 n0rb
n0rb
  • 2 posts
Posted 28 December 2013 - 06:39 PM
hey remotewizard,
sorry for my delayed response as well ;)
thanks alot for your instructions.
tested it quickly at work on an older netduino1 but couldn't get it to work (at all) unfortunately.
so I got a few more questions if you don't mind:
what netmf version are you using ?
the PWM constructor on netmf 4.1 and 4.2 seems to only accept one argument (PIN).
and are you using a netduino or netduino 2 ?
