Part Suggestions?
Posted 29 November 2010 - 08:52 AM
Posted 29 November 2010 - 09:45 AM
Could you share more details on how the mechanism is supposed to work? Is it similar to (for example) one inside an accordion? Could you replace lifting the pad with pushing the button (i.e. servo with a cam)? How about using solenoid air valve?The parts I'm emulating are just simple buttons and levers that lift a pad (from which air will escape). My initial thought was to use a servo to simply lift the pad, but then it occurred to me that I could replace the whole system with a solenoid.
Posted 29 November 2010 - 10:05 AM
All the mechanism needs is a button and a pad that lifts. Accordions, I believe, have very similar mechanisms, but I've never popped open one to check it out. The instrument I'm considering would be a member of the accordion family, but these instruments can be crazy-complex or just down-right simple; I'm going for something very simple (hopefully). If you've ever looked at a woodwind instrument (e.g., saxophone, clarinet, flute), then just about any key should demonstrate what I'm aiming for: a simple 'button' that when pressed lifts a pad (opening a hole from which air can escape). Does that help?
I'm really open to any mechanism that accomplishes the above feat. I imagine that a servo/cam option would certainly work, but I am concerned with the weight. Solenoids seem very promising, but I can't figure out where to start. The simpler and faster the better!
Thanks for the comment!
Posted 29 November 2010 - 11:29 AM
I see, thanks for the clarification. Accordion has similar mechanism, a pallet that covers tone hole is lifted when a key is pressed.If you've ever looked at a woodwind instrument (e.g., saxophone, clarinet, flute), then just about any key should demonstrate what I'm aiming for: a simple 'button' that when pressed lifts a pad (opening a hole from which air can escape). Does that help?
You'd probably need a linear solenoid actuator, which can be also made from a relay coil - usually, you can get them in amounts on various bargain sales and you could even reuse some of their mechanical parts. Netduino cannot drive coils directly, please refer to previous links for sample schematics how to switch inductive loads with a transistor. You can also use specialized drivers (integrated circuits) instead of discrete transistors, like Darlington arrays, power shift registers, etc. The selection of an actual device depends on coil voltage, max. current, communication interface etc.Solenoids seem very promising, but I can't figure out where to start. The simpler and faster the better!
Posted 30 November 2010 - 01:57 AM
Excellent example of what I'm trying to get at!
Wow, that's only a little bit intimidating. Any chance there are off-the-shelf options? If this is the only way, then I'll certainly start trying, but my project likely just got much harder and bigger than I had anticipated.
Upon reflection, really all I need is a way to 'instantly' allow and stop low pressure airflow. The idea of levers and pads seems like just one way to solve the problem... but I'm just not well-versed enough in mechanics/engineering to know where to start. I'm half tempted on just buying some random solenoids online and just trying to get them working. If I could at least get to a prototype stage, then I might have a better idea if I'm way over my head or not. Any suggestions on a basic solenoid that would work with the Netduino?
Also, just generally speaking, what suggestions do folks have for tools and parts for getting started?
Posted 01 December 2010 - 02:05 PM
I have just spotted Robotic Xylophone - you probably wouldn't want to make solenoids by yourself, but there are some useful ideas demonstrated, like interfacing with shift registers over SPI. You can use 74HC595 that can be easily chained to increase number of outputs, or even TPIC6B595/TPIC6C595 power version that has built-in output transistors and protection diodes.If I could at least get to a prototype stage, then I might have a better idea if I'm way over my head or not.
Posted 07 December 2010 - 06:33 PM
That video was genius! That's precisely the kind of thing I'm looking for, and I'm sure I can modify the concept easily for what I'm trying to do. I'll look into the parts you've mentioned.
Why would making my own solenoids be a bad idea? They seem pretty straight forward from the video. Any suggestions for an alternative, off-the-shelf option?
Thanks again!
Posted 07 December 2010 - 07:55 PM
Posted 08 December 2010 - 05:43 AM
my first instinct is to google pinball machine replacement parts, they tend to have lots of inexpensive solenoids...
ooo, excellent idea!
