OK, finally getting around to messing around with the netduino stuff I bought back in September at NYC Maker Faire, and of course, I'm having issues
The project I'm working on needs analog IO (have to fudge together a simple DC voltage monitor),
My issue is in getting the shieldbase to work...
I flashed the GO to 4.2.0.2, and the shieldbase to Beta4
When I go to run the following very simple project:
namespace NetduinoGoApplication1 { public class Program { public static void Main() { // write your code here NetduinoGo.ShieldBase sb = new NetduinoGo.ShieldBase(GoSockets.Socket5); AnalogInput dvm = new AnalogInput(sb.AnalogChannels.ANALOG_PIN_A0); while (true) { double dvmread = dvm.Read(); // Microsoft.SPOT.Debug.Print("foo"); } } } }
I get the following:
Create TS.
Loading start at 8056cf0, end 806e864
Assembly: mscorlib (4.2.0.0)
Assembly: System.IO (4.2.0.0)
Assembly: SecretLabs.NETMF.IO (4.2.0.0)
Attaching deployed file.
Assembly: NetduinoGo.ShieldBase (0.3.1.0)
Assembly: SecretLabs.NETMF.Hardware.NetduinoGo (4.2.0.0)
Resolving.
Link failure: some assembly references cannot be resolved!!
Assembly: NetduinoGo.ShieldBase (0.3.1.0) needs assembly 'GoBus' (1.0.0.0)
Assembly: NetduinoGo.ShieldBase (0.3.1.0) needs assembly 'GoBusSerialTransport' (1.4.1.0)
Assembly: SecretLabs.NETMF.Hardware.NetduinoGo (4.2.0.0) needs assembly 'GoBus' (1.0.0.0)
Error: a3000000
Waiting for debug commands...
HELP!
Edited by Stefan, 19 December 2012 - 06:42 AM.
Added [code] tags
