I just got the WiFly shield from Sparkfun and am testing it out with the Netduino Plus 2. When I tried to instantiate the shield, it just locks up. Here's my main method. The last thing the debugger would print is "Creating Wifly." Anyone know what might be the cause?
Thanks.
Debug.Print("Program starting");
OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
Debug.Print("Creating Wifly");
WiFlyGSX wifiModule = new WiFlyGSX();
Debug.Print("enabling dhcp");
wifiModule.EnableDHCP();
Debug.Print("Joining Network");
wifiModule.JoinNetwork("ssid");
Debug.Print("IPAddress: " + wifiModule.LocalIP);
SimpleSocket mySocket = new WiFlySocket("www.netmftoolbox.com", 80, wifiModule);
mySocket.Connect();
if (mySocket.IsConnected)
led.Write(true);
else
led.Write(false);
Hi mav29x,
I ran into the same issue. It was Stefan who pointed out the issue is actually with the Sparkfun Xbee Shield (WRL-09976). There is a missing pull-up on the board, which is not really needed when using an Xbee since they have it built into the actually module. However when you try using a WiFly module on this shield you will need to manually bypass the diode on pin 3 of the shield. If you look down through the comments of the shield's webpage you'll see that people have noted this error. They have since released a revision of the board that corrects this issue, however if you're like me, we missed out on it.
Instead I have just been using a Xbee breakout board (don't forget to buy the sockets and headers as they aren't included), my breadboard and some wires to directly connect the WiFly to my Netduino Plus 2. You only have to connect VCC, GND, DOUT and DIN pins to the Netduino for basic use.
Hi mav29x,
If I remember correctly, you may need to put the WiFly into a certain mode to configure it for the right baud rate...before trying to use it.
Which drivers are you using? Do they have any directions for initial setup?
Thanks Gutworks. I'm actually using this shield. Doesn't appear to be the same board as the Xbee Shield.
Hey Chris, I'm using the Toolbox.NETMF.Hardware.WiFlyGSX driver. Looking at the class library, it looks like the baud rate is set by default and I'm actually following the sample code that was provided.
I did some poking around. From the schematic, it looks like the Wifi Shield gets its power from pin VIN. What is the voltage supposed to be on that pin with respect to ground? I'm measuring 2.5V without the shield and it drops down to 0.8V with the shield attached.
Ah, yes. I forget there are couple WiFly versions out there. If I recall correctly, I had issues connecting to my network when I first got my WiFly. To resolve it I used Putty to connect to it and from there manually set the SSID, security settings and password. After that I had little to no issues with the Toolbox code.
Steve
One other thing. I think you may need to power your Netduino Plus 2 with an external power supply if the WiFly Shield uses VIN. I think the shield has its own voltage regulator on it and will regulate the VIN down to 3.3v for you. I'm not near my computer at the moment (using my phone), but will look at a little closer in the morning.
Steve
Thanks Steve. I think you're right about needing an external power supply. I have one coming in the mail and will retest the voltages once it arrives.
Hey Stefan, thanks for creating the driver!
Oh yes, great point Gutworks.
I believe that the WiFly shield does require an external power adapter (feeding into the power barrel or VIN/GND). This may be due to the amount of current that the shield needs to operate. The Netduino's 5V/3V3 headers can supply several 100 mA of power, but the shields are designed for the Arduino boards where 3.3V can typically only supply 50mA.
So I got my external power supply, powered it up and it's looking promising. The WiFly shield actually powered up with blinking lights and all. When I ran the same code in my original post, it's still stuck at the same place - just stops at instantiating the WiFly module. Is there something I can do to get it to work or do I really have to buy the XBee version?
I'm also using the WRL-09954 shield. If you're using this driver, and unless I'm completely mistaken, it won't work directly with a Wifly shield. It's designed to work with a WiFly module connected directly to a SerialPort. But the WiFly shield does not connect the WiFly directly to a serial port, it connects it through a SC16IS750 SPI-to-Uart bridge.
Today I started working on a driver class for the SC16IS750 that I'm hoping will perform all of the bridge-setup code, and return a descendent of SerialPort that you can pass into the Toolbox driver. (The Toolbox driver will require a small modification - a new constructor - but I think it should work)
I'll post here when I've got something to show - right now it just contains code to define all the registers and read and write them (didn't know what SPI was until today )
Apparently, the Microsoft NETMF team didn't want anyone to subclass the SerialPort class, and the SerialDataReceivedEventHandler and SerialErrorReceivedEventHandler classes both have internal constructors. I wish the MS team hadn't made those choices. So unfortunately I'm having to re-write part of the WiFlyGSX class to use a SerialPort-like interface, ISerialPort.
Thankfully only about 6 SerialPort members are used in the WiFlyGSX code, so it won't be too bad. If someone wants to come along and implement the rest of the ISerialPort methods/properties later, to make it a fully-functional SerialPort implementation, they're more than welcome.
I'll send a patch against rev 21420 of the toolbox code when I'm done. I'm hoping to have it functional today, and then get the code cleaned up and "presentable" afterward.
When setting up the toolbox I actually considered to make interfaces for the serial port, so you're doing a great job
Unfortunately, I didn't think this through very well. There is no way for me to make SerialPort class implement my interface. Which means that I can't create a common interface for the SPI Serial port class and the original SerialPort class.
if you want to take a look. It's not well documented, but it could be a good reference.
Maybe I should clean it up and post it to the public.
As soon as my Netduino Plus 2 arrives I will begin writing a firmware level driver so that I can use the NetworkInterface Class and all the goodies that go with it. SSL is the main thing I want to take advantage of.
Did you had any luck to get the Wifly module to work on your Netduino Plus 2 yet?
Hi Tenback,
I have had some success. I'm currently grappling with some sort of flow control/interrupt problem so it isn't ready yet. Basically, it either works perfectly, or fails waiting for a response to a command. Still trying to figure out what the cause those two results is.
At least the proof-of-concept is complete, so I know that if I can get this problem worked out, it should be useful for my project.
