What device are you connecting to? What speed?
I am connected to two [color=rgb(0,0,0);font-family:verdana;font-size:13px;]74HC595 with speed of 1000.[/color]
ChipSelect_Port: LatchPin,
Netduino Plus 2, SPI not working, .NET Toolbox,
Started by stotech, Dec 17 2012 09:04 AM
44 replies to this topic
#41Posted 12 February 2013 - 01:53 PM
ChipSelect_Port: LatchPin, ChipSelect_ActiveState: false, ChipSelect_SetupTime: 0, ChipSelect_HoldTime: 0, Clock_IdleState: false, Clock_Edge: true, Clock_RateKHz: [color=rgb(0,0,0);font-family:verdana;font-size:13px;]1000[/color],
#42Posted 07 July 2013 - 05:32 AM OK, This is a bit strange. I recently updated to the latest firmware and haven't tried the LCD in a while. Tried it over the last few days and I think it's bugged. After tons of trying and fretting that it was a bit shifting issue again I finally chucked the shield I was using and copied the website example. Still no go. So i thought the LCD might be dead and got a new one today. But know neither work at the moment so I'm thinking that I might be missing something or the Hd44780Lcd class doesn't work with the latest firmware? Here is what I've tried. using System;using System.Net;using System.Net.Sockets;using System.Threading;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.Netduino;using Toolbox.NETMF.Hardware;namespace screentest{ public class Program { public static void Main() { Hd44780Lcd Display = new Hd44780Lcd( Data4: Pins.GPIO_PIN_D4, Data5: Pins.GPIO_PIN_D5, Data6: Pins.GPIO_PIN_D6, Data7: Pins.GPIO_PIN_D7, ClockEnablePin: Pins.GPIO_PIN_D8, RegisterSelectPin: Pins.GPIO_PIN_D9, Columns: 20, Rows: 4 ); Thread.Sleep(2000); Display.ClearDisplay(); Display.Write("Hello World!"); Debug.Print("done"); } }} Found debugger!Create TS. Loading start at 806a988, end 8085288Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.IO (4.2.0.0)Assembly: System.IO (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0)Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)Assembly: Microsoft.SPOT.Time (4.2.0.0)Loading Deployment Assemblies.Attaching deployed file.Assembly: Toolbox.NETMF.Core (4.2.0.0)Attaching deployed file.Assembly: Toolbox.NETMF.Hardware.Hd44780Lcd (4.2.0.0)Attaching deployed file.Assembly: Toolbox.NETMF.Hardware.Core (4.2.0.0)Attaching deployed file.Assembly: SecretLabs.NETMF.Hardware (4.2.0.0)Attaching deployed file.Assembly: screentest (1.0.0.0)Resolving.The debugging target runtime is loading the application assemblies and starting execution.Ready.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2Assemblieslemscorlib.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Native.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Net.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleSystem.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.IO.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleSystem.IO.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.PWM.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.Usb.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Diagnostics.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.Netduino.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.OneWire.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Time.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Netmftoolbox.com.NET Micro Framework ToolboxAssembliesv4.2leToolbox.NETMF.Core.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Netmftoolbox.com.NET Micro Framework ToolboxAssembliesv4.2leToolbox.NETMF.Hardware.Core.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Netmftoolbox.com.NET Micro Framework ToolboxAssembliesv4.2leToolbox.NETMF.Hardware.Hd44780Lcd.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:FamilySkyDriveDocumentsProgrammingNetduinoscreentestscreentestbinDebuglescreentest.exe', Symbols loaded.The thread '<No Name>' (0x2) has exited with code 0 (0x0).doneThe thread '<No Name>' (0x1) has exited with code 0 (0x0).Done.Waiting for debug commands...The program '[5] Micro Framework application: Managed' has exited with code 0 (0x0). And the debug output?
Any suggestions? #43Posted 07 July 2013 - 07:24 AM grant: you need/want a thread.sleep(timeout.infinite) after Debug.Print("done");
its unknown what happens when you "close" the main loop. #44Posted 07 July 2013 - 07:55 AM Thanks for the quick reply. I've changed it but still no go. #45Posted 07 July 2013 - 12:44 PM After some looking around, it might be related to the speed difference between my N+2 and older netduino. I haven't got my old one to test anymore though? Can anyone else confirm using mftoolbox LCD class with netduino 2 on 4.2.2 0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
