Lost my MAC Address
Posted 26 November 2010 - 06:05 AM
Posted 26 November 2010 - 06:06 AM
- Charles likes this
Posted 04 October 2011 - 05:40 PM
- johnstaveley likes this
Posted 26 February 2013 - 07:15 PM
Hello,
On my side i'm using Netduino + V1, with firmware 4.2.0.1 update 1, and on my application i use 3 nd+ connected togather through ethernet.
board 1 acts as a data acquisition board.
board 2 acts as a display board
board 3 acts as a control board (buttons are attached to it).
Board 2 connects to Board 1.
And board 3 connects to Board 2.
On boot i use some delay in order to make sure the other boards are running.
SOmetimes it happens that my connect() call is hanging.
To avoid that i'm using some software watchdog to i need to reset programatically.
After the timeout period happens i do a
PowerState.RebootDevice(true);
With this my boards restarts and i can attempt to connect again.
Most of the time i don't need a restart but in some case i need it to avoid connection hang.
After a few restart i noticed that my module physical address of my board 3 is lost. ( when i check back i have the default mac address : 00-00-00-00-00-01)
Even if i reset the proper mac address after some time the board lost it.
What is does on my board 2, is that it kills my network comunication with board 3 and 1.
As my 3 boards are working togather if board 2 got it's network interface killed i need to reboot the 3 boards.
Even after the reboot as my board 3 has lost it's mac address the system stops working as soon as my board 3 starts to connect to my board 2 again.
Is it normal that the boards is loosing it's MAC address?
What can i do to avoid this stuff?
Can i setup programatically my board mac address at each start like this:
byte[] m_MacAdd = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06 };
networkInterface.PhysicalAddress = m_MacAdd;
some advice would be apriciated.
Posted 27 February 2013 - 02:58 AM
Which version of the .NET MF SDK are you using? The new .NET MF 4.3 SDK's MFDeploy appears to have some issues setting config settings on boards running earlier firmware.I did try as instruction above, but I got an error "Unable to erase configuration memory" See attachment
Can you try using our custom version of MDeploy?
http://forums.netdui...b-and-com1com2/
Posted 27 February 2013 - 02:59 AM
That shouldn't happen, but if you can create a simple repro (<20 lines of code...or a code-less scenario where it happens) we'd love to take a look. It is most likely a glitch in the lwIP networking stack. [There's also a new version of lwIP coming in NETMF 4.3...but that's a little ways off still.] ChrisAfter a few restart i noticed that my module physical address of my board 3 is lost. ( when i check back i have the default mac address : 00-00-00-00-00-01) Is it normal that the boards is loosing it's MAC address?
Posted 04 February 2014 - 10:15 AM
Hi, I am having the same 'Unable to erase configuration memory' problem on my Netduino Plus 1 board. 4.2 firmware on the board running the 4.3 SDK. I have tried to use the custom MFDeploy as suggested above but this does not even recognise my board. Any suggestions?
Posted 06 February 2014 - 01:37 AM
