I have successfully been able to write programs and download to my N2+, but after a program has been deployed, I am unable to debug again. Running MFDeploy I cannot ping the device. If I erase the device and reload the firmware, I can build and deploy another project, but I find myself in the same state again. It appears as if the N2+ is busy running the program I have previously downloaded. Also, when building the project in VS, if I remove the USB cable, my machine will blue screen and reboot. Any ideas what I am missing?
Unable to deploy using VS
Started by Mercer, Dec 08 2012 07:34 PM
Posted 08 December 2012 - 07:34 PM
Posted 08 December 2012 - 09:19 PM
If you create a new solution and deploy this simple program, it it still a problem ?
using System.Threading; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware.Netduino; namespace NP2.Blink { public class Program { static OutputPort led; public static void Main() { led = new OutputPort(Pins.ONBOARD_LED, false); while (true) { led.Write(!led.Read()); Thread.Sleep(100); } } } }
- Ulrik Lunddahl
Posted 09 December 2012 - 03:32 PM
Hi Mercer,
What is your app doing? Any chance that it's locking out the USB pins?
Ulrik's recommendation is a good one. Please try the blinky app, and see if the same issue occurs. If it does then we can diagnose it as a USB-driver-related issue. If it works fine then we can isolate the code/feature which is locking out the debugger.
Posted 09 December 2012 - 05:49 PM
Thanks for the reply.
I spent a lot more time with this yesterday and narrowed the issue down to the project I am trying to deploy. I am trying to deploy the web server written by neonmika, and am upgrading the project from 4.1 to 4.2 on the N2+. Once I deploy, the device is locked. See the following thread.
http://forums.netdui...__80#entry41239
I am not sure what else to check. The project builds okay, but will not successfully deploy.
