Hi guys,
I'm not sure if code questions belong here...
I recently started toying around with my netduino plus 2!
Cool stuff, but I'm trying to find my way around the basics.
Now, my girlfriend is using her arduino for some kind of school project and I was trying
to control a DC motor the same way she is doing...
http://pastebin.com/WgyHbeuL
Basicly what she is doing is writing values from 0 to 255 and back to 0... (she is not 100% sure whether that is the way it is supposed to be done... But that does not change my question)
With NetDuino I know we can write true or false using digital output, but for sending the values mentioned above I do not see any kind of way...
I tried googling around for PWM but I can't seem to understand whether PWM is the right direction...
If it is, how would I achieve this?
This may be a very basic question, I'm sorry
Analog Output signal with Netduino
Started by Frederik Prijck, Nov 27 2012 10:09 PM
Posted 27 November 2012 - 10:09 PM
Posted 27 November 2012 - 10:57 PM
first: i the stm32f4 has 2 analog outputs, but they are not exposed in the go/plus2 as far as i know.
so you have tu use pwm. pwm fits perfect for motor control (and i dont see it working with analog out ?! it has way too less power to drive anything other than a led)
its like that: you connect a pwm output pin to a resistor (like 2kohm+) to a transistors base. now if the transistor is strong enuff he can drive a motor, or he can drive a mosfet.
software side you set your pwm up to something like: frequenzy = 1000hz, and than change the duty cycle. 1.0f = 100% on, 0.5f = 50% on and so on. you finde more on this when you search for led dimming per pwm
//edit: what pwm means: with 1000hz you split a second into 1000 pieces, and the duty clyce says for how long each of this pieces is turn on. so with 0.5f it would make 1000 steps and every step if 50% of the time on and 50% of the time off, resulting in a total of 500msec per sec
Posted 30 November 2012 - 09:22 AM
Hi NooM,
With Netduino Go, we are supporting the AnalogOuput (DAC) class on GoBus modules. The Gadgeteer Adapter module will support DAC, and hopefully some other 3rd-party modules will as well.
The DAC on STM32F4 is not 5V tolerant, so we weren't able to expose it on Netduino Plus 2. We wanted to make sure users don't damage their mainboards when plugging in Arduino shields.first: i the stm32f4 has 2 analog outputs, but they are not exposed in the go/plus2 as far as i know.
