The Ethernet part (ENC28J60) alone on the N+2 consumes 150 mA, that along with the on-board led and potentially a uSD card could contribute to quite a bit of waste. If you plan on running your project off of a battery, you obviously want to get the power consumption down as low as you can. I've written up a small class with a single static method, and a single enum to make the process of turning off the peripherals easy.
Usage;
//Turn off the Ethernet controller
PowerManagment.SetPeripheralState(Peripheral.Ethernet, false);
//Turn off the uSD Card
PowerManagment.SetPeripheralState(Peripheral.SDCard, false);
//Turn off the Power LED
PowerManagment.SetPeripheralState(Peripheral.PowerLED, false);
//Turn On uSD Card
PowerManagment.SetPeripheralState(Peripheral.SDCard, true);
I don't have the public source code repositories up for Variable Labs just yet, so I've attached the source below.
Quick note;
I was looking through the schematic for the N+2 today and noticed that they way the power LED is turned off, there is no power savings when you turn it off, the power is just sinking to GND instead of lighting the LED. However the code can still be used to power it off if you don't want the light on
For the curious this is the relevant part of the schematic.
powerLED.PNG20.26KB73 downloads
This works extremely well. Thanks for the contribution Arron. I just upgraded my Pandora's Box device to use the Netduino Plus 2 and the first thing I noticed was the LCD's RGB Backlight was flickering and when I put it into scanning mode (basically activating all the sensors) the flickering got worse. Having the ability to turn the Ethernet Port and SD Card on when needed and off while scanning made a huge difference.
More importantly I think we need to thank SecretLabs for adding those mosfets Not having more control over what was going on, on the board was one of my biggest complaints about the Gen 1 devices. That and not having enough I/Os.
Arron - Thank you very much, I'll be utilizing your great work to use the POWER LED as a crude status LED along with the already built in status LED. Having control over both of them is very nice. I didn't end up using your full class but I never would have figured out how to grab control of the power LED without it.
//Turn off the Ethernet controllerPowerManagment.SetPeripheralState(Peripheral.Ethernet, false);//Turn off the uSD CardPowerManagment.SetPeripheralState(Peripheral.SDCard, false);//Turn off the Power LEDPowerManagment.SetPeripheralState(Peripheral.PowerLED, false);//Turn On uSD CardPowerManagment.SetPeripheralState(Peripheral.SDCard, true);
One change I made to the usage... If I am not mistaken you must set the PowerLED = [color=#0000ff;]true[/color] in order to turn it off. For readability I use two constants ON / OFF representing true and false in my code... so I made a change to accomodate this. Now it works as TRUE is on and FALSE is off. I remove the ! (NOT) from !state.
case Peripheral.PowerLED: if (peripheralPorts[1] == null) peripheralPorts[1] = new OutputPort((Cpu.Pin)Peripheral.PowerLED, state); else peripheralPorts[1].Write(state); break;
Odd problem I'm encountering. Wonder if anyone experienced it yet or has any thoughts. It's network related when power cycling the ethernet.
When my Netduino App Starts I am turning off both Ethernet and the Power Led to conserve power due to the numerous sensors and the LCD display using the following code:
// POWER MANAGEMENT// Turn off the Ethernet controllerPowerManagment.SetPeripheralState(Peripheral.Ethernet, OFF);// Turn off the Netduino Power LED. Not seen anyway.PowerManagment.SetPeripheralState(Peripheral.PowerLED, OFF);
From the menu on my Netduino App I put the Netduino into Host mode which in my case an an HTTP server that allows my windows app to exchange data and download log files. I am turning the Ethernet Back on before setting the network settings from a cfg file then starting the web server.
// Turn on the Ethernet controllerPowerManagment.SetPeripheralState(Peripheral.Ethernet, ON);Thread.Sleep(1000);// Code to start webserver//...
After starting the web server I can see the network settings are correct however I cannot PING or communicate with the ND+2. If I comment out the first line that turns off the Ethernet (never having powered it down) it runs 100% and I can PING and reach the box.
Is there something that needs to be done to initialize or reset the ethernet after powering it back up?
Quick note;
