Problems with debugging and deploying (Netduino Plus)
Posted 20 November 2012 - 09:24 AM
Posted 20 November 2012 - 09:55 AM
It's interesting as I am having that problem as well. Hardware setups which previously deployed OK are now failing for me in exactly the manner you describe. I did not have any real problems until I started using the latest builds of the SDK.Is the Netduino "bricked"? Or is there someone out there with some tricks up their sleeve?
Old config:
Netduino PLus and Netduinoi GO!
Cable used is the one I got with the Kindle.
Cable plugged into the laptop through a USB hub.
Now this worked fine for me for a while (i.e. over a year) until the last update I installed - currently 4.2 QFE3 I think.
This morning I have grabbed a new USB cable and plugged it directly into a USB port on the laptop. So far everything I have tried on both the Plus and the GO! works fine.
As an experiment, I have just swapped the Kindle cable for the new one which works on the laptop when connected directly and plugged it into the hub. Deployment on the GO! fails. And as a cross check, I plug the Kindle cable into the laptop directly and deployment works.
Wondering if there might be a driver issue when deploying through a USB hub.
Posted 20 November 2012 - 04:06 PM
Posted 20 November 2012 - 11:16 PM
Hi Troels, Mark:
Have you tried manually switching the drivers (from WinUSB to MFUSB) when using the latest firmware?
http://forums.netdui...-mfusb-drivers/
Thank you so much Chris! It looks like it worked! I'm now debugging and deploying without any problems, and the problems I had with DHCP also seems to be gone! What a relief. I actually bought a Netduino Plus 2 because I was so desperate, but well - Now I can enjoy two pieces of great hardware.
Looking forward to receiving my Netduino Plus 2
Posted 16 January 2013 - 07:17 PM
I just bought a netduino plus 2. The board has 4.2 version of the framework installed, and I'm using 4.2 SDK in visual studio. I've changed the USB driver to the MFUSB driver. I'm still getting the '... target is not in initialized state.... message when I use F5 to start debugging.
I tried using MFDeploy to regress the f/w on the board back to NetduinoPlus..fw 4.1.0.6. using these instructions:
I can ping the board in MFDeploy, I get 'Pinging...TinyCLR' I can browse out and select ER_CONFIG and ER_FLASH, but pressing Deploy brings up a 'Connecting to device' dialog which eventually bangs out to a 'Deployment Status' dialog with this text 'Erasing sector 0x0017e000', and an overlaid dialog saying 'Error:Unable to deploy to device'
Do I need to update my bootloader?
Thanks in advance
Erich
