ToggleButton sample
12 replies to this topic
#1 dab
dab
  • 54 posts
  • LocationBellevue, WA, USA
Posted 13 August 2010 - 06:39 AM
OK, here's my ToggleButton sample from the other thread "Using InterruptPorts".
This is basically like the Event Handlers tutorial on the Projects page. The main difference is that the pushbutton acts like a toggle - push once to turn off the LED, then push again to turn it back on.
Another slight modification - the interrupt handler method calls DisableInterrupt() at the start of the method, and EnableInterrupt() at the end. This seems to fix an issue where pressing and holding the button would sometimes cause the LED to change state when the button was released.
I think this might be due to switch bounce, so multiple interrupts were getting "stacked up" and handled after the first interrupt method returned.
Anyway, here's the code. Let me know if there's interest in posting the entire VS solution. Enjoy!
namespace ToggleButton
        static bool ledState;
        static InterruptPort button;
        static OutputPort led;
            // Set the initial state of the LED to on (true).
            ledState = true;
            led = new OutputPort(Pins.ONBOARD_LED, ledState);
            button = new InterruptPort(
                Pins.ONBOARD_SW1,
                false,
                Port.ResistorMode.Disabled,
                Port.InterruptMode.InterruptEdgeLow);
            // Bind the interrupt handler to the pin's interrupt event.
            button.OnInterrupt += new NativeEventHandler(SwitchInterruptHandler);
        public static void SwitchInterruptHandler(UInt32 data1, UInt32 data2, DateTime time)
            button.DisableInterrupt();
            // Invert the previous state of the LED.
            ledState = !ledState;
            // Set the LED to its new state.
            led.Write(ledState);
            // Un-comment the following line if using level interrupts.
            // button.ClearInterrupt();
            button.EnableInterrupt();
~ David ~
#2 CW2
Posted 13 August 2010 - 06:47 AM
Have you tried to enable glitch filter: button = new InterruptPort(..., true, ...) ? The debouncing time is controlable via CPU.GlitchFilterTime [^] property.
#3 dab
dab
  • 54 posts
Posted 13 August 2010 - 06:57 AM
I haven't tried the Glitch filter yet, thanks for the suggestion.
Do you happen to know what the default glitch filter time is (or what value is appropriate to debounce a pushbutton)?
~ David ~
#4 CW2
Posted 13 August 2010 - 07:01 AM
The official documentation [^] says 7.68 ms.
#5 José Ángel
José Ángel
  • 39 posts
  • LocationSpain
Posted 13 August 2010 - 11:17 AM
I have playing with the example on my silly emulator and works great :D http://forums.netdui...indpost__p__277
#6 dab
dab
  • 54 posts
Posted 13 August 2010 - 06:05 PM
Cool, thanks! I've been meaning to try out your emulator. So many projects, so little time... :(
~ David ~
#7 zee
zee
  • 47 posts
Posted 26 March 2013 - 01:20 AM
Hi Dab,
Is there any way that piezo speaker can be on/off too upon pressing the toggle button? I have a project to do, where song will be play through piezo if the button is been press & led on, and the song will be stop when the button been press again & led off.
#8 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 26 March 2013 - 01:57 AM
Put your song code in a separate thread.  Start and stop the thread using the button toggle code.
#9 zee
zee
  • 47 posts
Posted 27 March 2013 - 02:39 AM
Hi Dave,
You mind explain to me the steps? I am soooo noob in this netduino. Really new to me. Is it add new class or add new project?
I did tried to add both, but received few errors. Putting them in a different project, no errors but how to link? Add class, received lots of errors.
Appreciate your help :)
#10 zee
zee
  • 47 posts
Posted 27 March 2013 - 05:17 AM
Program.cs
using System.Net;
using System.Net.Sockets;
using System.IO.Ports;
using System.Text;
namespace PushButton_OutputMusic
        private static SecretLabs.NETMF.Hardware.PWM speaker = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D5);
        static System.Collections.Hashtable scale = new System.Collections.Hashtable();
                GetSound();
        private static void GetSound()
            //low octave
            scale.Add("c", 1915u);
            scale.Add("d", 1700u);
            scale.Add("e", 1519u);
            scale.Add("f", 1432u);
            scale.Add("g", 1275u);
            scale.Add("a", 1136u);
            scale.Add("b", 1014u);
            // high octave
            scale.Add("C", 956u);
            scale.Add("D", 851u);
            scale.Add("E", 758u);
            scale.Add("F", 191u);
            scale.Add("G", 170u);
            scale.Add("A", 153u);
            scale.Add("B", 136u);
            scale.Add("C2", 127u);
            // silence ("hold note")
            scale.Add("h", 0u);
            int beatsPerMinute = 90;
            int beatTimeInMilliseconds = 60000 / beatsPerMinute; //60,000 milliseconds per minute
            int pauseTimeInMilliseconds = (int)(beatTimeInMilliseconds * 0.1);
            string song = "C1C1C1g1a1a1g2E1E1D1D1C2h"; //old macdonald
            song += "C1C1G1G1A1A1G2F1F1E1E1D1D1C2h"; //twinkle little star
                for (int i = 0; i < song.Length; i += 2)
                    //song loop
                    string note = song.Substring(i, 1);
                    int beatCount = int.Parse(song.Substring(i + 1, 1));
                    uint noteDuration = (uint)scale[note];
                    speaker.SetPulse(noteDuration * 2, noteDuration);
                    Thread.Sleep(beatTimeInMilliseconds * beatCount - pauseTimeInMilliseconds);
                    speaker.SetDutyCycle(0); //set to 0, turn the piezo off momentarily
                    Thread.Sleep(pauseTimeInMilliseconds);
               Thread.Sleep(1000);
Next, Button.cs
using System.Net;
    class Button
        OutputPort led;
        bool ledState;
        public void buttonToggle()
        ledState = true;
            button = new InterruptPort(Pins.ONBOARD_SW1, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeLow);
            //bind the interrupt handler to the pin's interrupt event
        public void SwitchInterruptHandler(UInt32 data1, UInt32 data2, DateTime time)
            //invert the previous state of the LED
            //set the LED to its new state
Is this correct? The song auto play after i deploy. Then i pressed the button, the song stop and it starts automatically in few seconds. My objective is to make the song start and stop when pressing the button on Netduino..
#11 Chris Walker
Posted 30 March 2013 - 08:49 PM
Hi zee, Your button class isn't being used in your main program, so the button is acting as a software reset button (its default state). Chris
#12 zee
zee
  • 47 posts
Posted 01 April 2013 - 03:25 AM
But it works as it stopped the song and continue it automatically after few seconds. Could you guide me how should i put the Button class in Program.cs? Is it supposed to be in 2 different classes as shown above or all in one class?
#13 sebswed
sebswed
  • 45 posts
  • LocationSweden
Posted 15 April 2013 - 05:55 AM
Hi there.
I see in the code: "ONBOARD_SW1, false, Port.ResistorMode.Disabled",
Should that not be set to pull upp or down to debaunce the switch?
Netduino Plus 2 (v4.2.2.2)
