Netduino Plus 2 Native OneWire Temp Sensor
26 replies to this topic
#1 nickNetduino
nickNetduino
  • 12 posts
Posted 11 November 2012 - 11:00 PM
Ok folks, I've spent a day hacking this together but it appears to finally work. However, I was hoping some of the more experienced coders here might be able to critique this code to see what I may have not done very elegantly. Basically what the code should do is check the temperatures of 2 sensors ( DS18B20 ) every 10 seconds and store it in a global variable that may be read by a web client or logged. Thanks much in advance.
Sample Debug Output:
11/11/2012 19:03:25 Temp Inside: 67.8 Temp Outside: 44.4
11/11/2012 19:03:35 Temp Inside: 67.9 Temp Outside: 44.4
11/11/2012 19:03:45 Temp Inside: 67.9 Temp Outside: 44.5
11/11/2012 19:03:55 Temp Inside: 67.9 Temp Outside: 44.5
11/11/2012 19:04:05 Temp Inside: 67.9 Temp Outside: 44.5
        static OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
        static OutputPort owPort0 = new OutputPort(Pins.GPIO_PIN_D0, false);
        static OneWire owBus0 = new OneWire(owPort0);
        static byte[] owSensor1 = new byte[8] { 40, 168, 176, 219, 3, 0, 0, 221 }; //sensor 1 inside building
        static byte[] owSensor2 = new byte[8] { 40, 172, 164, 219, 3, 0, 0, 98 }; //sensor 2 outside building
        static float owSensor1Temp = -99;
        static float owSensor2Temp = -99;
        static DateTime tempReadingTimestamp = DateTime.Now;
            //set ip and get time from a time server
            Microsoft.SPOT.Net.NetworkInformation.NetworkInterface ni = Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0];
            ni.EnableStaticIP("10.10.40.80", "255.255.255.0", "10.10.40.1");
            SetTime();
            //create a web server
            WebServer server = new WebServer(80);
            server.CommandReceived += new WebServer.CommandReceivedHandler(server_CommandReceived);
            server.AllowedCommands.Add(new WebCommand("getTemp", 1));
            server.Start();
            //thread to blink the led every 250ms
            Thread ledBlinkThread = new Thread(BlinkLed_Delegate);
            ledBlinkThread.Start();
            //thread to read temps every 10 seconds
            Thread readTempsThread = new Thread(ReadTemps_Delegate);
            readTempsThread.Start();
            //loop
                //stay alive
        private static void ReadTemps_Delegate()
            Timer readTempsTimer = new Timer(new TimerCallback(ReadTemps_Tick), null, 0, 10000);
        private static void ReadTemps_Tick(Object obj)
            owSensor1Temp = GetOneWireTempByByteArray(owSensor1);
            owSensor2Temp = GetOneWireTempByByteArray(owSensor2);
            string debugString = tempReadingTimestamp.ToString();
            debugString += " Temp Inside: " + owSensor1Temp.ToString("N1");
            debugString += " Temp Outside: " + owSensor2Temp.ToString("N1");
            Debug.Print(debugString);
        static float GetOneWireTempByByteArray(byte[] sensor)
            float TemperatureC = 0;
            int tempLow = 0;
            int tempHigh = 0;
            int temptemp;
            owBus0.TouchReset(); //reset
            owBus0.TouchByte(0x55); //match rom
            foreach (byte b in sensor) //send the whole byte array
                owBus0.TouchByte(B);
            owBus0.TouchByte(0x44); //start temp conversion
            while (owBus0.ReadByte() == 0) ; //wait while busy
            owBus0.TouchByte(0xBE); //read scratchpad
            tempLow = owBus0.ReadByte(); //LSB
            tempHigh = owBus0.ReadByte(); //MSB
            temptemp = (((int)(tempHigh) << 8) | tempLow);
            TemperatureC = temptemp * 0.0625f;
            // temperature is negative if sign bit set
            if (!((tempHigh & 0x80) == 0))
                short t = 0;
                float result = 0f;
                // construct complete temp value
                t = (short)((tempHigh << 8) + tempLow);
                // if negative, take two's complement to get absolute value
                t = (short)-t;
                // get integer part if any
                result = (float)(t >> 8);
                // remove zero bits and add fractional part if any
                result += ((t >> 3) & 0x1f) * 0.03125f;
                // return value with correct sign
                TemperatureC = -result;
            return (float)((TemperatureC * 9.00 / 5.00) + 32.00);
  //left out some non essential code
Posted 11 November 2012 - 11:06 PM
Awesome, nickNetduino. Thank you for forging new paths and sharing this! First Netduino Plus 2 OneWire sample (using the NETMF OneWire classes). Cool :) I'll leave it to others to comment on the code. We're cooking up something here which I'm supposed to be approving the spec for...and working out a test plan for baxter's networking scenario...and I'll get too distracted if I dig in and start wiring up sensors using your code :) Chris
#3 nickNetduino
nickNetduino
  • 12 posts
Posted 11 November 2012 - 11:11 PM
One thing I would like comments on is: I put the LED blink routine and temp reading routine in different threads as I thought this would be best practice (is it?). However, why does the LED stutter every 10 seconds when the temps are read?
#4 carb
carb
  • 352 posts
Posted 11 November 2012 - 11:16 PM
Nick,
Looks cold outside, it 83 outside here in Florida, A/C is running.
What sensors are you using.
Thanks for postiong the code to help others get started,
Chuck
#5 nickNetduino
nickNetduino
  • 12 posts
Posted 11 November 2012 - 11:19 PM
DS18B20
#6 Chris Walker
Posted 11 November 2012 - 11:39 PM
Hi nickNetduino,
Do you have the blink routine on a timer? Or is it sitting in a tight loop in a thread?
NETMF's multi-tasking works best if routines don't "block" in tight loops. Also if the temp reading code takes a little while to execute (10s of ms) then the native code execution can hold up your managed code temporarily.
#7 nickNetduino
nickNetduino
  • 12 posts
Posted 11 November 2012 - 11:57 PM
Hi nickNetduino,
LED Blink is done using:
        private static void BlinkLed_Delegate()
            Timer blinkTimer = new Timer(new TimerCallback(BlinkLed_Tick), null, 0, 250);
        private static void BlinkLed_Tick(Object obj)
            led.Write(!led.Read());
#8 Chris Walker
Posted 11 November 2012 - 11:59 PM
nickNetduino, Hmm, it may just be the OneWire code taking a lot of time then. Do you have a feel for how long the actual OneWire transaction takes? Chris
#9 nickNetduino
nickNetduino
  • 12 posts
Posted 12 November 2012 - 12:03 AM
nickNetduino,
I think the stutter is ok after doing more research... The reads may take a full second. What really is buggin me now is after ~5 mins running, the led stops totally (randomly high or low) BUT the webserver still responds.
#10 Chris Walker
Posted 12 November 2012 - 12:08 AM
Hmm, very curious.
Can you put a Debug.Print at the front of the LED blinking function, and one at the beginning of the web server "accept" code?
And then we can see if the timer is stopped being called?
If so, there may be a NETMF bug to fix. Adventure :)
#11 nickNetduino
nickNetduino
  • 12 posts
Posted 12 November 2012 - 12:30 AM
Hmm, very curious.
Ok here is the latest... I've disable the web server entirely and the thing still hangs so I'm thinking the sensor reading code is screwing something up so back to my first post and hopefully someone can spot a big bug. Here is the debug output:
--NORMAL RUN FOR ABOUT 1 MINUTE....
LED BLINK 11/11/2012 20:27:26
LED BLINK 11/11/2012 20:27:27
LED BLINK 11/11/2012 20:27:28
11/11/2012 20:27:29 Temp Inside: 67.4 Temp Outside: 42.8
LED BLINK 11/11/2012 20:27:31
LED BLINK 11/11/2012 20:27:32
LED BLINK 11/11/2012 20:27:33
LED BLINK 11/11/2012 20:27:34
LED BLINK 11/11/2012 20:27:35
LED BLINK 11/11/2012 20:27:36
LED BLINK 11/11/2012 20:27:37
LED BLINK 11/11/2012 20:27:38
11/11/2012 20:27:39 Temp Inside: 67.3 Temp Outside: 42.6
LED BLINK 11/11/2012 20:27:41
--FROZEN BUT NO VISUAL STUDIO EXCEPTION THROWN
#12 Chris Walker
Posted 12 November 2012 - 01:03 AM
Hi nickNetduino, To confirm...is all your code stopping? Or is the web server code still working but the LED stops blinking? Chris
#13 nickNetduino
nickNetduino
  • 12 posts
Posted 12 November 2012 - 01:15 AM
Hi nickNetduino,
The output in the previous post is where I have totally disabled the webserver and both timers still appear to stop. With the webserver enabled, it appears to stay running even after the 2 timers die.
#14 nickNetduino
nickNetduino
  • 12 posts
Posted 12 November 2012 - 03:06 AM
Could garbage collection be at issue? Similar to http://forums.netdui...tes-five-times/
#15 Chris Walker
Posted 12 November 2012 - 03:25 AM
Oh my, I didn't even notice that. In ReadTemps_Delegate, you're creating a timer. Which will then get garbage collected at some point, since its scope is limited to the function.
Try creating a static variable for the timer outside of that function, and then instantiate it in that function instead.
#16 TalbotEv
TalbotEv
  • 7 posts
Posted 14 November 2012 - 10:59 AM
Does this also works for the Netduino Plus Version 1 ?
Also at the tick you create a new string everytime, i myself would make a public static string and fill that evertime.
So i would change this to:
and at the the static declarations at the top:
static string debugString;
#17 nickNetduino
nickNetduino
  • 12 posts
Posted 14 November 2012 - 10:31 PM
Thanks, I've made quite a few improvements and the code is a bit different now but I dont believe it will work with the original netduino plus because it needs to support native onewire. I believe there is a custom firmware with it's own onewire implementation that you can go with though.
#18 richy759
richy759
  • 3 posts
Posted 04 January 2013 - 12:55 PM
Just got my Netduino plus 2, this may seem like an obvios question but what namespace is OneWire under? I can't seemt to find it. I've updated to sdk version 4.2.1.
Thanks in advance,
Rich
#19 Chris Walker
Posted 04 January 2013 - 10:50 PM
Hi Rich, You'll want to add the Microsoft.SPOT.Hardware.OneWire.dll assembly as a reference to your project. The class is Microsoft.SPOT.Hardware.OneWire. Chris
#20 richy759
richy759
  • 3 posts
Posted 05 January 2013 - 04:12 PM
Thanks Chris
