Ultimately, I wish to have two Netduino Plus that communicate to each other with Streams over Sockets and both also communicate with a Desktop application in the same manner.
What I'm struggling with is discovery. I would like the Netdiunos and the Desktop app to be able to find each other on the network without manual configuration of IP addresses at runtime.
Any suggestion on how I could achieve that?
DPWS Substitute
Started by MaYHeM, Nov 07 2012 01:54 PM
5 replies to this topic
Posted 07 November 2012 - 01:54 PM
Posted 07 November 2012 - 02:22 PM
I haven't tried it yet, but I'm planning on doing the same scenario.
I think at network broadcast is the easiest way to do discovery, without DPWS.
ntools
http://ntools.codeplex.com/
Posted 07 November 2012 - 07:38 PM
MaYHeM ,
I wrote a simple VB.Net routine that sends a ping to NetduinoPlus in order to identify if my station in ON the network...if you need a copy of that simple code in VB, let me know...
With that routine, all you have to do is include a (FOR i= ) statemente to cycle from 1 to 254 in a specific domain...
Posted 07 November 2012 - 07:40 PM
MaYHeM ,
If you want Netduion doing discovery, I have a simple UDP routine where you can send a message and if you receive an echo of the message sent, you can use it like ping. I do not know how to implement a ping from Netduino, so I wrote my own version.
Posted 07 November 2012 - 07:46 PM
MayHem,
Just an idea...
byte[] MAC = { 0x5C, 0x86, 0x4A, 0x00, 0x4E, 0x5B };
Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].EnableStaticIP("192.168.1.101", "255.255.255.0", "192.168.1.254");
Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].PhysicalAddress = MAC;
//Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].EnableDhcp();
IPAddress remoteip = IPAddress.Parse(REMOTE_IP);
//IPEndPoint remoteendpoint = new IPEndPoint(System.Net.IPAddress.Any, REMOTE_PORT);
IPEndPoint remoteendpoint = new IPEndPoint(remoteip, REMOTE_PORT);
//Configura un socket para recibir Datagramas via Internetwork usando el protocolo UDP
Socket udp = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
//Vamos a procesar los broadcasts sin importar de cual estación vengan
IPEndPoint broadcastEndPoint = new IPEndPoint(System.Net.IPAddress.Any, REMOTE_PORT);
//Esta es la configuración para procesar comunicaciones UDP Broadcast, probado con el WireShark
udp.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
udp.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.Broadcast, true);
udp.SendTimeout = 100;
//Asocia el socket para procesar broadcasts UDP de cualquier estación en la red usando el puerto indicado
udp.Bind(broadcastEndPoint);
if (udp.Available > 0)
//Separa en RAM tanto Bytes como sean necesarios
byte[] byteReceiveBuffer = new byte[udp.Available + 20];
//Vamos a escuchar cualquier estación por el puerto definido
//EndPoint remoteEndPoint = new IPEndPoint(System.Net.IPAddress.Any, REMOTE_PORT);
EndPoint remoteEndPoint = new IPEndPoint(remoteip, REMOTE_PORT);
//Cuantos bytes llegaron y copialos
int iNumberOfBytes = udp.ReceiveFrom(byteReceiveBuffer, ref remoteEndPoint);
Posted 08 November 2012 - 04:56 PM
Thanks for the ideas.
